Author Topic: Heated saet  (Read 3189 times)
Dazzler
  • Haverhill, Suffolk
Heated saet
« on: 15 January 2009, 17:49:24 »
I have traced my heated seat fault to the seat back heater pad and not the base.
Has any one else had this part fail???? and is there a common place where the wire breaks or anything that i can look for??
I have at the moment bridged the wire so that i have at least the seat base heat pad working till i can fix the rear pad.
Any thoughts?
Re: Heated saet
« Reply #1 on: 15 January 2009, 18:06:21 »
Any thoughts?
You're putting twice the current though than it was designed for. They should, as you suggest, run in series with each other.
Re: Heated saet
« Reply #2 on: 15 January 2009, 19:17:57 »
Any thoughts?
Agreed. I might be inclined to live without it until you've fixed the faulty pad as you could end up fixing both - or applying calamine lotion to your @rse! :o
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Heated saet
« Reply #3 on: 15 January 2009, 22:52:02 »
Any thoughts?
lmfao!
V8!!!!
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Heated saet
« Reply #4 on: 16 January 2009, 19:25:58 »
Any thoughts?
Yes...
Smelt like burning cat... noticed smoke, then flames...
Needless to say the leather is goosed & I lost a perfectly good bottle of water in the process  >:(
Humbugs...
