Author Topic: Alternator  (Read 2038 times)
EliteV6
  • Sunny Torbay in Devon
  • Once driven forever smitten
Alternator
« on: 18 January 2009, 14:04:32 »
I own a 2.6 V6 (2002) model, need to get a replacement alternator, are the alternators the same from all the V6 Omega or do they differ?? ie 2.5, 2.6, 3.0 and 3.2?? Which ones will work, doesnt seem to be a part number on mine but its a bosch 120 amp one if that helps.
If there are diferent types which one is the best to try and get hold of.
Thanks
Omega Elite 2.6 V6 (2002)
vauxfan2k
  • Western Isles
Re: Alternator
« Reply #1 on: 18 January 2009, 14:06:45 »
I have a suitable replacement that will fit your car, its a bosch 120amp aswell, fully tested and in excellent nick
£20 +p&p if you need it  :y
EliteV6
Re: Alternator
« Reply #2 on: 18 January 2009, 14:41:38 »
Im gonna take mine apart and see if i can see any problems internally, bit skint till payday but if I havent had any luck I will give you a PM, any idea how much postage would be??
Many Thanks
vauxfan2k
  • Western Isles
Re: Alternator
« Reply #3 on: 18 January 2009, 14:46:26 »
depends how you want it sent, 1st class will be about 8 something, parcelfarce probably not much less.
If you take off the black cover at the back of the altenator you will see the regulator (black oval shape with 2 screws securing) thats probably the fault, on the other hand it could be the brushes so means a refurb kit needed.
« Last Edit: 18 January 2009, 14:46:48 by Vauxfan2k »
Ian_D
  • York
Re: Alternator
« Reply #4 on: 19 January 2009, 00:48:13 »
Are the brushes not part of the regulator? Thought it was all in one? Could be getting mixed up with another altenator i've seen though!
[size=12]
Re: Alternator
« Reply #5 on: 19 January 2009, 08:41:50 »
Yes they are, and I am yet to see them close to worn out (even on a 200K mile alternator).
There are only two things that happen to these units
1) Noisey bearings - cheap and easy
2) Regulator failure.
The 2.6 and 3.2 do use a lightly different alternator to the 2.5 and 3.0 which I seem to recall is 140amp
It also has a very large regulator pack which is not to cheap!
You can fit the 2.5/3.0 alternator without issues though
