Author Topic: Problem with Speedo!!  (Read 3027 times)
V6CDBOY
  • Wiltshire
« on: 23 January 2009, 20:04:33 »
Just fitted a new double din stereo to my 2001 miggy, switched it on all working fine.
Went for a drive speedo not working, unplug stereo speedo works!!!
Any Ideas as to what I can do to rectify.
  :o :o
Re: Problem with Speedo!!
« Reply #1 on: 23 January 2009, 22:06:48 »
Dsconnect the pin that Vauxhall use as SDVC - I suspect your stereo uses that pin for something else and is dragging it high or low
V6CDBOY
  • Wiltshire
« Reply #2 on: 23 January 2009, 22:15:04 »
Thanks
how do I know which pin that it as the new H/U's ISO plug is completely full ie 8 on top and 8 on the bottom.
Cheers
« Reply #3 on: 23 January 2009, 22:23:37 »
Thanks
Cheers
Which radio did you remove?
V6CDBOY
  • Wiltshire
« Reply #4 on: 23 January 2009, 22:27:08 »
It was a CRD2005(E)
V6CDBOY
  • Wiltshire
« Reply #5 on: 23 January 2009, 22:36:37 »
I don't know if it helps but the ISO Block is as follows:
Top 8 pins relate to the 4 speakers.
Bottom 8 pins are GND, Batt+, Acc, PRK SW, P.12v out, P.GND, Reverse and Ant. Cont
 :D
« Reply #6 on: 23 January 2009, 22:42:53 »
It was a CRD2005(E)
checking
« Last Edit: 23 January 2009, 22:48:13 by TheBoy »
V6CDBOY
  • Wiltshire
« Reply #8 on: 23 January 2009, 22:47:12 »
Thanks, can I just remove the pin from the block and wrap in insulating tape or should I just snip the wire?
V6CDBOY
  • Wiltshire
« Reply #10 on: 23 January 2009, 22:57:01 »
Thanks a lot
One final question can you remove a pin from the block??
« Reply #11 on: 24 January 2009, 09:19:48 »
I always use a traffic master or similar loom to make all mods on, so I don't have to butcher the car's loom.
eg http://cgi.ebay.co.uk/CAR-RADIO-STEREO-ISO-EXTENSION-WIRING-HARNESS-16-PIN_W0QQitemZ370054744340QQcmdZViewItemQQptZUK_Cars_Parts_Vehicles_Terminals_Cabling_ET?hash=item370054744340&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
If you go down this route, ensure the adapter you get is suitable first, and has all the pins you need populated.
But to answer your Q, you can remove the pin, but it has a 1-way tag that may get damaged.
