Author Topic: which radio unit to use  (Read 3372 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 26 January 2009, 21:26:57 »
I've just got hold of a 2000 w 3.0 elite estate but it had a CDR 205 VDO in it. When i took the unit out as itdid not work correctly it had normal radio con box plus two single gray leads and one black single lead. i was also told the antenna was for sat nav(bigger bottom end than normal)? I think its a GID in it as well(half size display) and it has a bose system. Which system do i use? it dose not have phone in glove box.
Re: which radio unit to use
« Reply #1 on: 26 January 2009, 21:34:36 »
If you have a GID, you need a NCDC2013 or NCDC2015.
Trouble is, unless you have the carpass, you may need to replace GID as well.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #2 on: 26 January 2009, 21:40:10 »
was given a car pass with the car but is the correct one?
« Reply #3 on: 26 January 2009, 21:44:44 »
it will need a bit of tech2 once you have found a radio, where abouts are you
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #4 on: 26 January 2009, 21:47:04 »
im in swindon wilts
« Reply #5 on: 26 January 2009, 21:49:53 »
im in swindon wilts
hmmm, we have tech2s in Alton, and up above oxford - http://theboy.omegaowners.com
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #6 on: 26 January 2009, 22:00:20 »
just looked at the car pass and it looks like it is not for the car. How much of job does make it?
« Reply #7 on: 27 January 2009, 21:11:42 »
You'll need to replace the GID - we haven't found a way of unpairing the GID yet.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 28 January 2009, 15:56:54 »
OK! How much do they go for and do i have to sale the house to pay for it? I may have found a ncdc2015 which they say has never been fitted to anything, or do they have to come together. If so has any one got a set and how much? The omega does sound very nice but i would like sum music now and then and it would nice to have it from the correct unit. Can any one help?
« Reply #9 on: 28 January 2009, 17:47:27 »
The NCDC series radios and their associated displays, particularly the colour display, are very sought after.  Expect to pay a hefty price premium to get a depaired set, or set prepaired to each other.
