Author Topic: Pressure switch  (Read 4218 times)
Techno
  • Bedfordshire
Pressure switch
« on: 28 January 2009, 16:12:51 »
Does anybody know where the low pressure switch/sensor is on the aircon system?
Re: Pressure switch
« Reply #1 on: 28 January 2009, 17:48:43 »
On A/C pipe near rad.  The switch itself is pretty reliable, far more likely to be a (lack of) refridgerant problem
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #2 on: 28 January 2009, 17:57:32 »
 Ok, its bloody odd I only had it re-gassed in Oct and it packed up by Dec.
I've checked the whole system (that I can see) and there is no trace of dye anywhere  >:(
The guy pressure checked the system for about an hour and there was no loss, he said if was was a leak it would have showed up in that time by a slight pressure drop.
I'm really not going to waste another call out fee until I've made sure the switch is working.  I suppose it could be the clutch how can I test this or loop it so it should run?
Bloody annoying £70 possibly wasted  >:(
Re: Pressure switch
« Reply #3 on: 28 January 2009, 17:59:42 »
Live data, iirc, can tell you if its over pressure or under pressure (I'd need to double check).
I'll wager a pound its got a leak...
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #4 on: 28 January 2009, 18:00:34 »
Yer I bet but where?
Re: Pressure switch
« Reply #5 on: 28 January 2009, 18:01:39 »
condensor is favourite
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #6 on: 28 January 2009, 18:03:28 »
I'm guessing you cant see that?
Where is it and how do you get at it do you know?
Re: Pressure switch
« Reply #7 on: 28 January 2009, 18:54:17 »
My leak was the compressor.  :(
Re: Pressure switch
« Reply #8 on: 28 January 2009, 18:55:15 »
The condensor is the 'radiator' infront of the main cooling rad.
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #9 on: 28 January 2009, 21:29:04 »
I've checked all around that no dye
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #10 on: 28 January 2009, 21:30:17 »
Hmm cant say I've completely checked this but I will do.
Techno
  • Bedfordshire
Re: Pressure switch
« Reply #11 on: 29 January 2009, 17:39:27 »
I've checked it and I can't find any dye traces?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: Pressure switch
« Reply #12 on: 31 January 2009, 10:17:08 »
I thought the dye they put in was UV sensitive - i.e. will only show up under a UV light..?  Half a chance that all the recent wet weather has washed it all off by now..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
