Author Topic: Starting issue  (Read 2365 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Starting issue
« on: 04 January 2009, 19:10:50 »
Just got back from over 1000 miles on the road this week - no problems. However, turn ignition key and it just clicks - turn off and on again and it starts as normal. This has happened twice in last 3 days.
Battery is only a year old - could this be a bad connection arising from recent engine change when VX will have had all the bits out to refit on new one?
I think VX battereis are guaranteed 2 years so maybe I will start from there by getting it tested.
Re: Starting issue
« Reply #1 on: 04 January 2009, 19:17:25 »
dodgy starter solenoid? poor engine earth?
pscocoa
Re: Starting issue
« Reply #2 on: 04 January 2009, 19:22:51 »
Thanks - in the technical info section - you posted a photo of the v6 engine bay but it does not stretch over to the full battery shot - since the new engine was fitted something looks different around the battery area but I cannot put my finger on it. Should the negative terminal have a cover over it? Also the block wiring at the back of the battery on mine looks as though it should have protection around it (I think it used to) but does not now - ie. you can see the coloured wires.
I may try and do photo tomorrow if I do not make progress on the other items.
Re: Starting issue
« Reply #3 on: 05 January 2009, 15:10:25 »
Could be the starter interlock switch which prevents you starting the car in gear. This is integrated into the gearbox selector switch, I believe. Might be worth trying waggling the gear selector next time. see if that helps.
If you are actually getting a "clunk" from the starter motor I would suspect the starter motor, solenoid or possibly a bad connection.
pscocoa
Re: Starting issue
« Reply #4 on: 06 January 2009, 12:37:41 »
the interlock switch is favourite I think - is this easy to get at?
Re: Starting issue
« Reply #5 on: 06 January 2009, 13:41:49 »
Remove gearlever surround by prising up the plastic trim and you will be able to see the switch :y
Re: Starting issue
« Reply #6 on: 06 January 2009, 14:06:39 »
I have a feeling the starter interlock is inside the main gear selector switch, which is mounted on the gearbox where the selector shaft enters the 'box?
The switch under the centre console stops you removing the key unless in Park.
I may be wrong...
The other thing to try is to move the gear selector to "N" before starting.
pscocoa
Re: Starting issue
« Reply #7 on: 24 January 2009, 16:02:44 »
I may be wrong...
kevin - it is acting up again - when they put the new engine in they would have had to reconnect gearbox obviously - do you think they could have failed to connect this interlock switch correctly - is it a big job to get at it if it is not the switch under the plastic gear lever cover?
pscocoa
Re: Starting issue
« Reply #8 on: 04 February 2009, 14:43:23 »
Update - problem solved - thanks to all and Kevin Wood via PMs.
It is my dealer again - went in today on spec (car was booked in gfor friday but can't make it now) as did not think their diagnosis was correct and insisted that before I commit to £212 on the interlock switch replacement - that they check the connection to the starter motor. Hey presto - when they fitted new engine the feed to starter motor was not tightened up.
Now sorted - no charge.
Off to Cornwall again friday so glad this intermittent fault now dealt with.
Thanks again
