Author Topic: Radio Display  (Read 2780 times)
rc2325
  • West Lothian
Radio Display
« on: 25 January 2009, 09:25:54 »
Firstly Hi to all on this forum.  :)
I recently bought a 2.2 Auto (2001) & the display from radio (CDR2005 Delco) is not showing any station info.
It is showing the fuel consumption, range & the date ok, but not the outside temperature. (tried replacing the sensor under the front bumper but this never worked)
I can live with the outside temp not showing but the lack of radio station info is driving me nuts.  :-?
Any help would be appreciated.
Re: Radio Display
« Reply #1 on: 25 January 2009, 10:48:20 »
What does outside temp show? -F?
As for radio, does display show date when radio off?  Does the date disappear when radio switched on?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio Display
« Reply #2 on: 25 January 2009, 11:52:16 »
Is the wiring OK at the rear of the radio? Has it been previously modified for another radio?  If power removed from radio, does code entry screen appear, and then dissappear when code entered?
Radio & Decoding Technician
www.dndservices.co.uk
rc2325
  • West Lothian
Re: Radio Display
« Reply #3 on: 25 January 2009, 12:04:19 »
The Temp display shows 'Outs Temp F  C'
When the radio is off the display has the date shown. & yes, when the radio is turned on the date disappears.
I only recently purchased the car so not sure on history of radio changes. Had the unit out and all connections seem ok.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio Display
« Reply #4 on: 25 January 2009, 12:12:11 »
Did radio ask for a code when refitted?
rc2325
  • West Lothian
Re: Radio Display
« Reply #5 on: 25 January 2009, 12:19:58 »
No, it just turned on & played straight away, although with no station info displayed.
Re: Radio Display
« Reply #6 on: 25 January 2009, 17:48:38 »
Sounds like a poor connection on 1 (or more of 3 pins), or radio set to wrong display type (didn't think the facelift ones were adjustable though)
rc2325
  • West Lothian
Re: Radio Display
« Reply #7 on: 25 January 2009, 22:53:13 »
Will check out the connections again, cheers
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
Re: Radio Display
« Reply #8 on: 30 January 2009, 01:36:55 »
I had a similar problem to this on mine. you could hear the radio but didn't a clue what the staion was, was thinking it was buggered and might need to replace it, turned out it was a bit loose, so pushed the unit in a bit futher and it displayed the station. sometimes the simple solutions are the best!
07 Volvo V70 T5 SE ex police
rc2325
  • West Lothian
Re: Radio Display
« Reply #9 on: 31 January 2009, 11:48:40 »
OMG i cant believe i just got it to work by doing the exact same. Pulled the cage out and seated the connection better & it worked.  ;D
thanks very much for every ones help, its appreciated.  :y
oceansoul
  • Sunbury on Thames - Surrey
Re: Radio Display
« Reply #10 on: 04 February 2009, 17:12:05 »
so how come it didnt ask for the code after you took it out :s :s
Re: Radio Display
« Reply #11 on: 04 February 2009, 17:43:13 »
Code may be disabled.  Also, if its a NCDx series, security works a different way
Page created in 0.023 seconds with 20 queries.
