Pages: [1] 2 3  All   Go Down
Author Topic: C D Player  (Read 12041 times)
V6CDBOY
  • Wiltshire
C D Player
« on: 17 January 2009, 17:04:20 »
Looking to fit an over the counter CD player, I got the relevant filler piece for when I remove the VX original, will I need to replace the wiring harness or is it a universal one?
Any advice
vauxfan2k
  • Western Isles
Re: C D Player
« Reply #1 on: 17 January 2009, 17:11:33 »
its standard iso connectors on the omega's, the only thing you might need to do is swap the perm live with the ign live, as some stereos are wired the other way round from vaux.
Re: C D Player
« Reply #2 on: 17 January 2009, 17:22:41 »
Only ISO isn't necessarily standard any more...
Woodfull
  • Taunton
Re: C D Player
« Reply #3 on: 17 January 2009, 18:53:37 »
Have today replaced mine with a double din JVC HU.
If you want to retain steering wheel control functionality the new HU will need the facility, not all have it, and you'll need one of these:
http://ice.dndservices.co.uk/shop_show_item.php/IID/344
You'll also need a patch lead to match the make of HU you are fitting,
PC99-JVC, PC99-SON, PC99-ALP and so on. The above link to Dave dnd's webpage explains it all.
I did indeed have to swap over the red and yellow wires as mentioned above, the harness adaptor has that facility so it's dead easy.
On the down side you do end up with an awful lot of cable to stow, especially if you go double din, achieved it ......just!!
Single din and fascia adaptor should will give you more room  :y :y
« Last Edit: 17 January 2009, 18:55:48 by Big_Steve »
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #4 on: 17 January 2009, 20:24:57 »
Cheers All
 :y :y
Martin_1962
Re: C D Player
« Reply #5 on: 19 January 2009, 22:12:42 »
I had trouble shoving mine in - ended up merging two addon looms into one.
I have a MD head unit, DOPS005 display driver, ISO-Sony lead, CD changer lead, phonos from CD phonos to amp and an unused other adaptor for Traffic Master but missing some wiring.
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #6 on: 20 January 2009, 10:17:09 »
Cheeky question!!!
Is there away of removing the HU without the VX tool.
Re: C D Player
« Reply #7 on: 21 January 2009, 12:17:35 »
Cheeky question!!!
Yes, i have used small bobble ended allen keys in the past, but its possible to damage/pull off the facia on mine this way, the keys are available from halfords for only a few quid.
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #8 on: 21 January 2009, 18:07:09 »
Cheers, I'll by a pair.
Another question before I take out the old unit. Will there be a standard ISO Connection behind or am I in for a shock?
 ;D
Re: C D Player
« Reply #9 on: 21 January 2009, 19:15:19 »
A facelift will have a 36way iso connector at back.  The top block of this connector (20 pins) isn't really defined in the standard, so nothing will be truely plug and play
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #10 on: 21 January 2009, 19:18:59 »
Ok so if it's  not just a plug in job is there a link on here to what cable does what by any chance as I dont wnat to short the new unit by wiring in wrong?
Re: C D Player
« Reply #11 on: 21 January 2009, 19:22:15 »
The pinout varies with which HU is fitted.
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #12 on: 21 January 2009, 19:24:10 »
Ok thanks for that, probably best to get it professionaly fitted in that case unless anyone can give me advice??
Re: C D Player
« Reply #13 on: 21 January 2009, 19:28:39 »
If you are confident with electrical stuff, and know what you're doing, diy.  If you're not, probably a good idea to use expert.
V6CDBOY
  • Wiltshire
Re: C D Player
« Reply #14 on: 21 January 2009, 19:30:03 »
Bugger!!!
Pages: [1] 2 3  All   Go Up
