Author Topic: Double Din cd player and phone system  (Read 2350 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 06 February 2009, 11:41:50 »
Apart from the CCRT 2008, is there any other double din unit suitable for the Omega which has a CD player and can take a sim card?
Thanks.
Re: Double Din cd player and phone system
« Reply #1 on: 06 February 2009, 21:33:50 »
NCDC2015, but needs wiring mods from your ccrt2008, and the phone unit is seperate and sits in the glovebox.
Whats wrong with phone in your ccrt then?
  • Doha, Qatar
« Reply #2 on: 07 February 2009, 13:57:22 »
The phone is fine, but it's the CD player thats knackered. Plus it doesn't light up. I know the removable panel lights up as it lit up on another unit.
The other CCRT 2008 unit that I have needs the Code index progamme as you've previously identified. But explaining that to the Opel dealer here is altogether another issue.
So another option is to try another unit as CCRT 2008's seem impossible to get hold off.
« Reply #3 on: 07 February 2009, 20:01:08 »
I have one here ::)
  • Doha, Qatar
« Reply #4 on: 08 February 2009, 03:50:59 »
PM sent........
« Reply #5 on: 08 February 2009, 09:53:10 »
just thinking - did you have 2 2008s?  can't you make 1 good from 2 bad?
  • Doha, Qatar
« Reply #6 on: 08 February 2009, 10:08:21 »
Yes, I do. I thought that as well. The only reservation I have is that the one with the working CD has the configuration missing. I've assumed that if I swapped this CD unit over it wouldn't work. Maybe worth a try?
« Reply #7 on: 08 February 2009, 10:15:58 »
The CD changer from your old one will work with new radio - they are not coded :)
