Author Topic: Omega / Vectra The similarities  (Read 13273 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« on: 09 October 2006, 20:04:54 »
Ok
Vectra sri 2,6 v6 - is this the same engine ( 03 model) that is in the latest 2.6 omegas
Does anyone know the model  of engines?
why.....tell you later  ;)
Gwilym
  • Bridgwater, Somerset, UK
Re: Omega / Vectra The similarities
« Reply #1 on: 09 October 2006, 20:39:58 »
Are you considering a transplant?
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Markie
« Reply #2 on: 09 October 2006, 20:44:34 »
no no no but if i had to source an engine for a 2.6sri vectra i am wondering if it needs to be from a vectra or s it the same as the 2.6 late model omegas.  :-/
Gwilym
« Reply #3 on: 09 October 2006, 20:48:38 »
They came out at the same time and I would not imagine VX creating 2 different engines of the same size in the same year as R&D is so expensive.
Probably only drive that is different.
However I am only giving my opinion, I have no mechanical skill whatsoever.
mr des
  • limerick, ireland
  • Doh
« Reply #4 on: 09 October 2006, 20:51:51 »
same block but the manifolds and gearbox ends will be different IMO
i want to shine in the eye of orion but i drove my sole through the black hole
« Reply #5 on: 09 October 2006, 21:37:25 »
If its anything like Vectra 2.5/Omega 2.5, same basic engine, but all intake/manifold/g/box etc all different...
« Reply #6 on: 09 October 2006, 21:41:46 »
Same block, heads and management system
Different inlet and exhaust manifolds, fly wheel, clutch, sump........so yes, a An Omega base could be used in a Vectra if certain bits were swapped over.
Martin_1962
« Reply #7 on: 09 October 2006, 21:42:49 »
I suppose a VEctra could supply an engine for an Omega
« Reply #8 on: 09 October 2006, 21:45:45 »
Same applies, if bits swapped over, its possible...
Markie
« Reply #9 on: 09 October 2006, 21:54:27 »
would the vectra be fbw  ?
I may have the chance of a very late very cheap vectra 2.6 suspect hgf  ::) now i have never heard of vauxhall v6`s having hgf - we all know for example the oil coolers tend to go.
But i am working on the worst case scenario hat it is top end damage and ( just for bad luck) bottom end damage and i need a new engine!!
v6 vectras prone to hg failure? or could it be something more sinister or even something more simple ( calling all veccys)
« Reply #10 on: 09 October 2006, 21:57:48 »
All 2.6's are FBW.....even in the vectra......headgasket failure....unlikely.....
Markie
« Reply #11 on: 09 October 2006, 22:07:31 »
thought so on both counts
so purley on a hunch Mark what would it likely be if a muppet mechanic tells you your 2.6 v6 has hg failure? Oil cooler again?
« Reply #12 on: 09 October 2006, 22:08:32 »
sounds like oil cooler, unless its done mega miles...
Markie
« Reply #13 on: 09 October 2006, 22:11:34 »
33k 02 plate mot`d 6 weeks ago.......
I know we cant diagnose a car from a one line description but i am ust thinking that i really really doubt the head would go and its probably easier than heads......
Intresting...... i can feel by bank account twitching  ;D
« Reply #14 on: 09 October 2006, 22:13:14 »
Would be very unusual if it was HG.  Plus, I reckon you have abilities and equipment to do even if it was ;)
Pages: [1] 2 3 4  All   Go Up
Page created in 0.045 seconds with 20 queries.
