Author Topic: Omega / Vectra The similarities  (Read 13240 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Omega / Vectra The similarities
« Reply #45 on: 11 October 2006, 20:09:31 »
well its pretty messy - i reckon there must have been some serious pressure as it has forced the top off - the pics will show what i mean, however if it had forced the top off theres no gunk on the soundproofing under the bonnet - so i reckon its shot down or over sides....oh jeez i dont know as i was looking in a downpour in the dark.. !!!!!!
........cant do much right now as i have no garage space - it should support 3 cars but with a me having  a bleeding v6 omega in bits , a freezer, washing machine, pool table, 2 engine hoists and god knows what else....oh and then  theres a renault to attent to - no in fact make that two.... :-/
i really really dont have time for the veccy but it was far too good to miss out on so t can sit in a corner and sulk untill... ;D
some pics to follow.....
this one is self explanatory
as is this one
oil nice and oily in here no gunk !!
and this oil is fine - NOT nothing on the dipstick to suggest a problem
Nice enough...
Ok apologies for going on about vectras i will say no more  :-X
...apart from i have used a new id elsewhere and posted on another forum in the relevant car / technical section and got no response since yesterday   :-X
« Last Edit: 12 October 2006, 13:17:57 by Markiec »
« Reply #46 on: 11 October 2006, 20:21:30 »
Oil cooler......when the oil gets at the coolant tank lid seal it distorts and throws oily coolant everywhere.
The insides like a bit dirty....
Markie
« Reply #47 on: 11 October 2006, 21:48:08 »
so compression test, oil cooler,
obviously needs a few flushes of oil and fortes/ coolant flush several times.
Would you take the heads off to have a lok see at this stage..... or try the above first....? :-/
« Reply #48 on: 11 October 2006, 21:58:21 »
Leave the heads where they are and drop an oil cooler in.
Flush the system and check the plug wells for oil and go from there.
Markie
« Reply #49 on: 12 October 2006, 13:24:19 »
thanks Mark, oil cooler is it on TC?
i wont be doing it, as mentioned untill i get the cdx away, meantime today -
decided - as i had a hunch - to fill some coolant into the header - not much mind...i had a squeeze about the radiator hoses and there wasnt much happening. True to form the coolant dribbled straight out again - bottom of the radiator.  Also removed battery and header tank.
Clearly the radiator is goosed....so its what happened first time ( chicken and egg time)
 radiator - hole - leak of coolant - pop goes everything
or oil cooler - block - heat - radiator...oh i dunno back preassure and off with the cap ?.... :-/
deal with a few hgf rovers but boy had i forgotten how hard it is to get the mayo off everything.........
under battery tray and beyone ( looking down ) gunk as fa as the eye can see - note however its ALL come from header
a shot from under neath - taken from front paessenger side - gunk gunk gunk gunk gunk bloody gunk
« Last Edit: 12 October 2006, 13:25:38 by Markiec »
Pages: 1 2 3 [4]  All   Go Up
Page created in 0.024 seconds with 20 queries.
