Pages: 1 [2] 3  All   Go Down
Author Topic: boot cd changer fitting  (Read 9018 times)
Richie London
  • heathrow
Re: boot cd changer fitting
« Reply #15 on: 12 February 2009, 14:15:52 »
the connector fits ok. im just totally puzzled. i know my pc has to warm up or it wont work if its unplugged at the mains for too long, would this be the same
Is this a new-to-you changer? I know there are 2 similarlarly labelled changers that are different from each other.
mine is a ccrt700, the connectors are ok, its sending a singal to the radio but just says error up on screen. so i have the right changer i presume.  :-/
The Boy or Dave DND are the men to ask, but my changer (I have a CCRT700 too) is a CDC2. It has the numbers 90 566 804 but i think the all importnat number is 7 607 797 321 on the label underneath the unit.
Sounds like it may be an incompatable changer. Although it may say CDC2, there are 11 varieties of this, and they are not cross compatable. The all important number is the 10 digit part number starting 7 ??? ??? ???  and you need to get the correct part number changer for use with your head unit. Others may be able to advise which version is correct for you to look out for as I`m afraid I do not have a list here.
thats the one ive got
Richie London
  • heathrow
« Reply #16 on: 12 February 2009, 14:57:50 »
just found a thread from marks dtm and i quote:
Ok, some extra info for those trying to source a replacement CDC2 for your vehicle.....Beware!
There are two version of this unit used on Vauxhalls and they are NOT compatible!
The units have a two digit ID on them as follows:
FA - Suitable for all radios that do no have Phone function
FC - Only suitable for radios with phone function (i.e. CCRT700)
i have:
7 607 797 321
90 566 804
type cdc2
W1G
FD.
so what does the FD mean, i have the phone on mine.??
« Reply #17 on: 12 February 2009, 15:26:41 »
Don't know, but I'm sure mine has FD on it too.
Richie London
  • heathrow
« Reply #18 on: 12 February 2009, 15:42:33 »
dont know what to do now, will try again in a min for the last time  :(
« Reply #19 on: 12 February 2009, 15:45:12 »
Is there anyone local to you with the same CCRT700 that you can swap changers with to try?
« Last Edit: 12 February 2009, 15:45:31 by Andy_B »
vauxfan2k
  • Western Isles
« Reply #20 on: 12 February 2009, 18:55:37 »
could it be possible the laser is duff? was it tested prior to you buying it?
if it was and working, then maybe internally damaged in the post if its the correct one for your headunit.
cheers
Richie London
  • heathrow
« Reply #21 on: 12 February 2009, 19:07:45 »
i wouldnt know to be honest. everytime i turn it on it searches for dsic but comes back disc error after every disc number.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #22 on: 12 February 2009, 19:20:52 »
That would suggest a duff laser maybe?
Excellent idea by Andy B though, do you have a fellow Ooofer nearby that could swap quickly to confirm the changer is at fault
Radio & Decoding Technician
www.dndservices.co.uk
Richie London
  • heathrow
« Reply #23 on: 12 February 2009, 19:36:35 »
i'll have to have a look on the map, i know theres 3 very near me.  :y
« Reply #24 on: 12 February 2009, 19:39:08 »
Faulty laser or (if its only certain slots) the mag
Richie London
  • heathrow
« Reply #25 on: 12 February 2009, 19:42:08 »
its all slots at the end it says error 1,2,3,4,5,6. then goes onto radio. can it be diagnosed in a shop.
Richie London
  • heathrow
« Reply #26 on: 12 February 2009, 19:42:47 »
maplins is up the rd.
thanks folks  :y
« Reply #27 on: 12 February 2009, 19:43:09 »
laser then.  try a known good one to confirm.
Richie London
  • heathrow
« Reply #28 on: 12 February 2009, 19:46:31 »
x25xe lives about 4 miles from me, has same car, same spec, same yr. will send him a message to see if he can try his in my car.
cheers
Richie London
  • heathrow
« Reply #29 on: 12 February 2009, 19:47:58 »
FA - Suitable for all radios that do no have Phone functionFC - Only suitable for radios with phone function (i.e. CCRT700)
i have:
7 607 797 321
90 566 804
type cdc2
W1G
FD.
as higlighted ??
Pages: 1 [2] 3  All   Go Up
