Author Topic: speaker upgrade  (Read 3861 times)
tunes
  • essex
speaker upgrade
« on: 10 February 2009, 19:10:05 »
was looking into upgrading my speakers in my 99 cd
i was informed to get the bose speakers out of a elite as i would be hard to match the quality of them unless i wanted to spend alot of money
this true? they really that gd?
blooming hope so coz just bought a set off ebay lol
« Last Edit: 10 February 2009, 19:10:34 by tunes »
IF I WANT TO GO IN A STRAIGHT LINE, IL BUY A FORD
dpanic88
  • West Midlands
Re: speaker upgrade
« Reply #1 on: 10 February 2009, 19:39:10 »
Hi, have you also got the amp as well? I believe you cannot just install the bose speakers without the correct head unit / amp as the output is different?
Someone will 100% confirm soon
Regards
Big Sye
  • SLady bitshorpe, South Humberside
  • Hero's Don't Die!!! - They Reload!!!
Re: speaker upgrade
« Reply #2 on: 10 February 2009, 19:44:27 »
if you wanted to change the standard speakers for some after market ones.  do you have to use them silly plastic speaker housing things to change to aftermarket ones.?
Big Sye
(Midnight-Modified.co.uk)
Martin_1962
Re: speaker upgrade
« Reply #3 on: 10 February 2009, 20:32:58 »
Yes - I have Infinity components in mine but a standard head unit struggles to drive them
MutantCav
  • Gainsborough
Re: speaker upgrade
« Reply #4 on: 10 February 2009, 21:39:26 »
Yeah Bose speakers are 2 Ohm unlike the 4 Ohm normal Omega ones...also need Bose head unit and amp minimum plus probably the loom
« Last Edit: 10 February 2009, 21:39:44 by ShieldOfSteel »
tunes
  • essex
Re: speaker upgrade
« Reply #5 on: 11 February 2009, 02:13:38 »
i have a aftermarket headunit as i dnt like the standard ones as the car is recieving some heavy audio upgrades
the speakers are supplied with all conversion leads
i just wondered if they sounded good?
Miggy24
  • Exeter,Devon
Re: speaker upgrade
« Reply #6 on: 11 February 2009, 09:34:23 »
i have just put some new speakers in my car.i went down to halford and brought the spacers for a corsa and they fitted no probs.I think aftermarket ones sound so much better then the vx standard ones :y
Big Sye
Re: speaker upgrade
« Reply #7 on: 11 February 2009, 09:38:27 »
i think standard Vx ones are only about 20 watts.   how cheap are the spacers for aftermarket speakers
Big Sye
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: speaker upgrade
« Reply #8 on: 11 February 2009, 09:38:42 »
Correct   :y
Radio & Decoding Technician
www.dndservices.co.uk
Miggy24
  • Exeter,Devon
Re: speaker upgrade
« Reply #9 on: 12 February 2009, 08:54:12 »
you can buy the sparcers on ebay for about a tenner :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: speaker upgrade
« Reply #10 on: 12 February 2009, 14:56:38 »
Fitting Bose Speakers to any Head Unit is not a good idea, as correctly said earlier there 2 Ohms, (Bose's way of screwing a bit more power from there systems) most HU are disigned for 4 Ohm. Some Amps claim to drive 2 Ohm Speakers but your then into trying to set up all the EQ to try and suit the Bose Speakers.
Best bet is either go for a Bose system retrofit (if its cheap enough) or rip it out and start again.
« Last Edit: 12 February 2009, 15:32:07 by zirk »
Miggy24
  • Exeter,Devon
Re: speaker upgrade
« Reply #11 on: 14 February 2009, 08:27:19 »
i say rip it out and start again thats what i did and brought some nice speakers,sub and amp to go in the back sounds stop on  :y
