Author Topic: NCDC/GID/Telematics (VXL V6)  (Read 4644 times)
« on: 15 February 2009, 16:42:20 »
Thought I'd make this a public discussion so everyone can join in, rather than private between VXL V6 and I.
VXL V6 kindly loaned OOF some NCDC, displays, and telematics units to try to further assist with decoding these units.
What was supposed to be there was:
NCDC2015/GID/Telematics all with unknown code.
NCDC2013/GID with known code.
Telematics, new, unpaired.
The bad news is that the Telematics paired with 2015 won't power up.  Been round it with a meter, reckon there is a problem with the 0v internally - need further advice on that one.
Even more bad news is the supposedly unpaired telematics is already paired with an unknown code.
Good news is we are quite adept at decoding paired NCDC/NCDR series radios - done my 2, MDTM's, and now this one, so the process definately works :D.
Had a good look around the top board on the nokia telematics, couldn't really see a likely candidate for where the code is held - there is a 29 series AMD flash on there??
Any help whilst we have VXL V6's telematics would be really helpful :)
    • 530D M Sport, 330i Coupe
Re: NCDC/GID/Telematics (VXL V6)
« Reply #1 on: 15 February 2009, 18:12:58 »
What information are you looking for TB?
Would a known working unit help the diagnosis process? If so would anyone have a telematics unit that they could manage without for a short period?
Any help would be appreciated on this one as this is the final link in the chain of the NCDC/NCDR Head units and CID/GID Display units pairing / coding  :y
« Reply #2 on: 15 February 2009, 18:18:35 »
Someone capable of repairing those nokia Telematics units ideally to start with - get your other one repaired.
« Reply #3 on: 15 February 2009, 18:22:16 »
Perhaps Dave DND might like to have a look? Bit of a rare beast with very little information on the Internet  :(
« Reply #4 on: 15 February 2009, 18:28:21 »
I guess I could have a good look at one if it helps!
« Reply #5 on: 15 February 2009, 18:33:44 »
Yes please! Is the OOF courier service available?  ;D
EDIT: Just sent an Email to Nokia, I won't hold my breath waiting for a reply though!
« Last Edit: 15 February 2009, 18:38:07 by VXL_V6 »
« Reply #6 on: 15 February 2009, 18:36:40 »
TB and I need to get together at some point as I have two CID boards, a Bose tray, a flight case and a wedge of cash here for him
« Reply #7 on: 15 February 2009, 18:38:38 »
I know you're a damn sight better at lifting chips than I am.
The 0v on the non working one, comes in on pins 31/32, but never makes it to what appears to be the main 0v areas (inc the case). strangely, there appears to be caps between pins 31/32 and the main 0v grounding parts where the case attaches.
The working one (as in fires up and communicates - still duff code) has a dead short between 31/32 and the case.
It appears to be a multi layered board, so little chance of tracing tracks.
Signs of dampness in the connector.
Reckon it would be OK to stick a jumper wire between 31/32 and the main 0v tracks?
« Reply #8 on: 15 February 2009, 18:39:43 »
Oh goody - I have a spare, working lcd for one of tthose cid boards :y
« Reply #9 on: 15 February 2009, 18:42:44 »
Now here's a bit of news - ignoring the fact its a tedious job to set it all up, it seems that the telematics works, even though it has teh wrong pairing code  :-?
« Reply #10 on: 15 February 2009, 19:01:26 »
If I remember correctly we assumed that the powerdown is controlled over CAN as there is no ign switched live to the telematics. I wonder if it senses the loss of CAN communication when the HU is off and starts a power off timer. My point is that with the HU off the Telematic is still on (and working) but lacking the pairing code from HU and Screen.
« Reply #11 on: 15 February 2009, 19:10:12 »
no, its firing up and powering down as expected (obviously via can)...  ...live data for tm shows ID OK (ie, its happy with hu's security)  :(
Just when I thought I understood these things..........
« Reply #12 on: 15 February 2009, 19:17:32 »
Must be something different about Telematics requirements of pairing to the HU's and Screens then?
« Reply #13 on: 15 February 2009, 19:22:12 »
something doesn't make sense, as I've difinately seen as Telematics Safe msg before  :-/
« Reply #14 on: 15 February 2009, 19:26:13 »
Revision of the Telematic? Though I doubt that the pairing requirement was ever any different.
