Author Topic: What is this? (key fob)  (Read 7774 times)
Martin_1962
« on: 13 February 2009, 21:04:41 »
Inside the red circle
Re: What is this? (key fob)
« Reply #1 on: 13 February 2009, 21:24:41 »
mdtm or kevin wood will know better, but looks like cap to me
Martin_1962
« Reply #2 on: 13 February 2009, 21:35:08 »
Waiting for one of those 2
Ended up using wire to replace the track and it works without the possible cap
    • 530D M Sport, 330i Coupe
« Reply #3 on: 13 February 2009, 21:48:16 »
It looks the same as the one just below on what appears to be the aerial (square spiral type track) so would guess it's a cap as well - maybe used as a filter in the case of the aerial.
Martin_1962
« Reply #4 on: 13 February 2009, 23:18:25 »
Well it is going back without one  - I hope it works
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 13 February 2009, 23:23:44 »
it wont work without it martin its a capictor  :(
Martin_1962
« Reply #6 on: 13 February 2009, 23:26:25 »
Why not? - it gets picked up on RF at the correct channel
I expected it not to work but was surprised it did
markey mark
« Reply #7 on: 13 February 2009, 23:30:30 »
well its there for a reason bud ! if its missing so is a part of the cicuit  :(
Martin_1962
« Reply #8 on: 13 February 2009, 23:47:01 »
Oh well if I knew its value and could get one - I'll see what happens - have emailed and PMed - said suck it and see
« Reply #9 on: 14 February 2009, 11:39:40 »
Its a cermaic cap......looks to be a 10-100nF and probably a de-coupling cap
Martin_1962
« Reply #10 on: 14 February 2009, 12:07:48 »
I'll check Maplins later
Martin_1962
« Reply #11 on: 14 February 2009, 12:14:43 »
How do you learn all this electronics stuff - I'd love to learn more? :'(
« Reply #12 on: 14 February 2009, 14:52:54 »
5 years as a hobby, 4 years full time at Uni.....then you are ready to learn it (you dont learn the real stuff till you leave!)
11 years later.....and I can design my own stuff well!
Martin_1962
« Reply #13 on: 14 February 2009, 18:00:36 »
I suppose like it takes a good 10 years of programming before you can call yourself one.
Ian_D
  • York
« Reply #14 on: 14 February 2009, 19:44:07 »
Does look like a cap to me too, but could it also be a resistor? (Or do they normaly have numbers on them?)
You will probably find it will work without it anyways!
Bit like on computer hard drives, often diodes fail (shorted) and you can remove them and continue to use the hard drive again to recover files etc... Wouldn’t use the drive again for anything important though without resoldering another diode in place, even the I would be sceptical!
« Last Edit: 14 February 2009, 19:48:40 by Ian_D »
[size=12]
