Author Topic: omega 3.0v6 converted to manual  (Read 2101 times)
paulsmv6
« on: 23 February 2009, 18:09:27 »
hi there i hav just bin reading up on the manual converstion of a omega 3.0v6 and i read up on the wire for the ignition timing retard if this hasnt bin done wot problems wud it cause wud it cause. :y thanks
Re: omega 3.0v6 converted to manual
« Reply #1 on: 23 February 2009, 20:22:40 »
hi there i havE just bin BEEN reading up on the manual converstion of a omega 3.0v6 and i read up on the wire for the ignition timing retard if this hasnt bin BEEN done wot WHAT problems wOuLd it cause wOuLd it cause. :y thanks
No idea.  :-X  :-/ :-/
http://www.omegaowners.com/forum/YaBB.pl?virboard=Newbies;num=1209458172
General Posting
Use English, no text speak which is notoriously difficult to read.
paulsmv6
« Reply #2 on: 24 February 2009, 18:32:46 »
i will cut the wires anyway must b a reason for it thanks anyway :y
« Reply #3 on: 24 February 2009, 18:40:55 »
There is a post in the maintenance guides telling you what to do....there is a minimum of one single wire that needs changing on the engine ECU to default it to manual mode.
