Author Topic: Steering Wheel Controls  (Read 2960 times)
furrymunkey
  • N.E Scotland
« on: 23 February 2009, 18:11:04 »
I want to take the steering wheel controls off my 97 vectra cdx and fit them to the Omega. Is it possible to change them over without having to remove the steering wheel, and will I need anything apart from the controls?. I've also found that they dont seem to work with the Philips SC804 as I tested the SC804 HU I gt from the scrappy to see if it worked, which it does but the steering wheel controls on the vectra wont work with it, but they work fine with my normal vauxhall stereo.
Re: Steering Wheel Controls
« Reply #1 on: 23 February 2009, 18:18:50 »
Pretty certain to need new contact unit, and wiring to HU.
Pretty certain sc804 doesn't have remote control functionality
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 23 February 2009, 22:52:40 »
I`m not aware of a version of SC804 that has steering compatability either.
Radio & Decoding Technician
www.dndservices.co.uk
furrymunkey
  • N.E Scotland
« Reply #3 on: 24 February 2009, 21:55:18 »
Do you know which vauxhall headunits will work with steering wheel controls, cd changer and trafficmaster, as I found the Oracle doesn't talk to the sc804 either.
« Reply #4 on: 24 February 2009, 22:06:48 »
Factory fitted to Omegas?  CAR400, CDR500, CCR600, CCR800, CCRT700. You have facelift I presume so won't cover facelifts
« Last Edit: 24 February 2009, 22:07:01 by TheBoy »
« Reply #5 on: 24 February 2009, 22:07:43 »
Note, some of the above can be programmed to be compatible or incompatible with remote controls
furrymunkey
  • N.E Scotland
« Reply #6 on: 24 February 2009, 22:08:21 »
It's pre-fadelift 1997.
furrymunkey
  • N.E Scotland
« Reply #7 on: 24 February 2009, 22:09:10 »
Facelift even....might be right enough with the fade part though....they are dying out  ;D
