Author Topic: Where do i buy some super bright xenon H1 hulbs?  (Read 9280 times)
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« on: 21 January 2009, 10:02:20 »
I have a 2002 2.2 omega and wish to change my headlight bulbs to those fancy super bright xenon healdight.
I changed my original H1 bulbs with the ebay ones that promised to be Xenon super bright..but to be honest.. they were absolute rubbish...the bulbs did seem bright,but they were very poor.
I got so frustrated..I put back the original bulbs. However i have seen some omega with the xenon bulbs and they look very nice.
Where can i buy those really bright H1 bulbs,cost is no object as i have already wasted about £40 fiddling with cheap bulbs.
Can someone please recommend a good brand/make ?
Cheers.
Re: Where do i buy some super bright xenon H1 hulbs?
« Reply #1 on: 21 January 2009, 10:59:48 »
To get 'proper' Xenons - ie, HIDs - as fitted to top spec cars you need to replace headlights, add an automatic levelling system, and headlight washers.
Its not a case of simply replacing the bulbs, its a very different setup.
For yours, Osram Nightbreakers or Philips +50 are supposed to be the best option.
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #2 on: 21 January 2009, 11:47:47 »
Thanks TB. Will try the osram.
DaviesEB
  • Monrovia Liberia
« Reply #3 on: 21 January 2009, 15:29:22 »
Let me know what that total is. I will also want to change mine . I have an Omega Estate 2.5 V6
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #6 on: 22 January 2009, 17:10:55 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=190281671176&ssPageName=STRK:MEWN:IT&ih=009
£13.50 in total
About £1.50 more than the other ebay site then  :)
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
petey
  • Before 'ze Germans get 'ere
« Reply #7 on: 23 January 2009, 18:52:06 »
similar spec bulbs are used on some agricultural machinery so you could check some proper garden equipment places, i.e not b&q, and they should be cheaper, HM Plant used to sell them for £5 or so each..
minilandrover
  • france
  • My other car is a HALF SIZE LANDROVER
« Reply #8 on: 20 February 2009, 22:51:26 »
hello there, i bought a set of blue 100 h1's from china, cost about 8 euros delivered to france, they are fine but one  went dark after a few weeks. just bad luck, the problem with higher wattage bulbs though is that they will draw more current, ok we all have got a big alternator so no worry, but the wiring has to handle twice the amperage, and if you get a voltage drop on any bulb the light will be dimmer. :-/ in fact a 100w bulb that only gets 11.6v will be dimmer that a 50w bulb getting 13.6v. so measure the voltage and if the drop is worying then fit a decent relay to each buld, powered by very thick cable straight from the battery. result is very bright instantly lighting lights.  8-) mine are great, oh and t cut your lenzes if they are dirty, helps too. :y
colin
want a laugh?  take a look at landrover v tree on www.youtube.com     this how i do gardening with a landrover,   im building a petrol half size army light weight landrover for fun  250 kgs of bad attitude
miniator
  • Northern Ireland
    • My YouTube Channel
« Reply #9 on: 21 February 2009, 20:34:51 »
forget cheap ebay items, been there done that.....
http://www.autobulbsdirect.co.uk/h1-high-performance-c-604.html
any of those are top notch but hte rally sport ones at 130w are brilliant. i had 100/160w H4's fitted to my old civic and the light was HID bright! will be buying some for my motor shortly!
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #10 on: 21 February 2009, 22:04:04 »
I can recommend the Osram Nightbreakers .... i have them in mine  :y
« Reply #11 on: 22 February 2009, 19:50:05 »
Little chance of that as they will be at best half the light output of a HID
Onkel Per
  • Frederikshavn - Denmark
« Reply #12 on: 22 February 2009, 20:18:29 »
To have the best look ahead and to see what's in front of you, use Osram Night Breaker or Philips VisionPlus.
And if you are outside UK, you might take a look on Philips NightGuide DoubleLife. Almost as bright, but twice the lifetime.
A 55w bulp should be bright enough.
If you think you need 100W bulps, it might be time to check lamp lense and reflector. Or go visit your opticeian  ;)
« Last Edit: 22 February 2009, 20:35:49 by Onkel_Per »
nick v6
  • walsall / west midlands
« Reply #13 on: 22 February 2009, 20:54:50 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=270329134629
12 quid and a bit including postage to the uk
i had my bulbs from that person and they popped the following day
only had about 2 hours use total if that
« Reply #14 on: 23 February 2009, 11:09:18 »
Send them back.....mine have been fine.....probably over 100 hours use now
Page created in 0.028 seconds with 20 queries.
