Author Topic: NCDC 2015 CD-Changer problem  (Read 3840 times)
Kait
  • Tallinn, Estonia
« on: 03 January 2009, 14:55:24 »
I have ncdc 2015 and my cd changer stopped working. It recognizes discs but as it tries to read them you can hear how laser lens is trying to focus cd and display says " ERROR CDx"
Connected "My Naff Code Reader" and cd-changer was having CD Focus error fault problem. :(
Took the radio inside...cleaned cd-ch lens with compressed air and cotton stick. Nothing. :(
Took it apart on the table, connected the power and looked it while operating...laser beam was there...and lesns focusing was woking too.
Adjusted the laser lens intensity....didn't work. So I quess the laser diode is faded out or smth. :-? Any other ideas?
Does it needs to focus first and then will start spinning cd because it will not spinn cd, only moves a little bit while focusing?
I noticed that cd-ch uses KSS-601a laser lens. Is there any place where I could purchase this lens online?
Happy new year! :)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: NCDC 2015 CD-Changer problem
« Reply #1 on: 03 January 2009, 15:08:54 »
Sounds like the NCDC has been playing CDR's???
if it has the laser fitted to these units doesnt like CDR's very much and it wears it out
speak to a forum member called DaveDND he is our audio Guru and he offers a repair service
http://www.omegaowners.com/forum/YaBB.pl?action=viewprofile;username=002532211B000A00440   thats his profile
« Last Edit: 03 January 2009, 15:11:44 by tmx »
Kait
  • Tallinn, Estonia
« Reply #2 on: 03 January 2009, 15:48:36 »
yes indeed it has been played cd-r's :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 03 January 2009, 17:26:49 »
Unfortunatley, by using non-compatable CDR`s, the laser has strained itself so hard to read the smaller data recorded, that it has worn itself out.
If you can get a new laser and have the ability to recalibrate it once fitted, then thats what you need to do, but not something I can assist with on that model I`m afraid.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #4 on: 03 January 2009, 19:20:25 »
Yeah, knackered laser.  I believe new pick-ups are available from 1 or 2 places on this unit.
Kait
  • Tallinn, Estonia
« Reply #5 on: 03 January 2009, 22:53:25 »
Ok. I'll try to find this lens from Estonia first...if no luck...then....I don't know what then.... :(
« Reply #6 on: 04 January 2009, 08:05:27 »
If anybody finds a cource for these optical pickups then lt me know as I am not able to find one at all.....I can for the Nav section though!
Kait
  • Tallinn, Estonia
« Reply #7 on: 04 January 2009, 23:33:28 »
what marking is the ncdc2015 sat-nav laser? in case i need it later. ;)
also it seems that kss-601a is almost impossible to find,
 i noticed that kss-602a looks almost exactly as kss-601a only difference i see is that ribbon cable connection end has different angle or something.
« Last Edit: 05 January 2009, 00:34:29 by kait »
Kait
  • Tallinn, Estonia
« Reply #8 on: 25 February 2009, 17:01:51 »
as i have no luck with finding new laser for ncdc2015 cd-changer, i was wondring: can i swap mechanism including laser from Philips CDC3 with ncdc2015 cd-changer one to get ncdc working??
« Reply #9 on: 25 February 2009, 18:12:44 »
yup.  need to reuse you 2015 interface board
Kait
  • Tallinn, Estonia
« Reply #10 on: 04 March 2009, 18:24:35 »
Bought cdc3 from uk ebay. Swapped the mechanism and voila, it works like new :)
