Author Topic: base vacum system to electronic climate control  (Read 2943 times)
drefts
« on: 02 March 2009, 21:02:26 »
hi. new here. :-)
i have a opel omega b1 2.5td CD 1995.mod with base vacum heat control.
i wonder if i could put in a electronic climate control in stead.
do i have the right electric connectors, is it just the panel and servo's i need?
 sorry for my english. norwegian user here.  ;) :y
Have this:
Want this:
Re: base vacum system to electronic climate control
« Reply #1 on: 02 March 2009, 21:19:36 »
Nothing is impossible.  But converting to climate is pretty close to impossible!
Would be a big, big, big, BIG job.  I would doubt anyone has ever attempted it.
    • 530D M Sport, 330i Coupe
« Reply #2 on: 02 March 2009, 21:29:31 »
Seen it done on a Vectra B (The CDX model has single zone climate). It entails removing more than just the panel as the whole system control is via motors / actuators on various parts of the air blower system and obviously a different loom.
drefts
« Reply #3 on: 02 March 2009, 22:29:31 »
ok.  8-)
thanks for fast answer think i will keep the old style. to next car  :y
drefts
« Reply #4 on: 02 March 2009, 22:56:40 »
what about TC traction control. can i mount that?
see in electric diagram i only need 3 wires from the switch.
But is the connector on my abs pump the same on abs pump with traction control?
« Reply #5 on: 03 March 2009, 18:43:43 »
TC not available.  To be honest, it doesn't need it, unless its chipped...
drefts
« Reply #6 on: 03 March 2009, 22:02:22 »
it is chipped. and the roads in norway is not good on winter. :-D.
so you tell me it would not work to after mount traction control?
« Reply #7 on: 04 March 2009, 19:39:50 »
Not tried myself, but not sure the engine ECU has the capability, certainly it appears the wiring is missing.  Not sure if its a different ABS ECU, or if its just programming on the ABS ECU
