Author Topic: Rear door speaker size  (Read 2184 times)
Martin_1962
« on: 05 March 2009, 19:27:01 »
What size can they take and is there any room for a seperate tweater as opposed to a coaxial design?
doog
  • Alloa Central Scotland
Re: Rear door speaker size
« Reply #1 on: 05 March 2009, 19:41:20 »
rear doors are 5 1/4  and there is a space in t he grill for a tweeter
I had to make up mdf spacer rings to get mine to fit
Doug
« Last Edit: 05 March 2009, 19:49:14 by doog »
me at kick boxing
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 06 March 2009, 08:57:20 »
or even better, if you take a look at the back of the door trim card you should see a circle scored out in the trim.
if you cut it out i found the tweeter from my infinity componants fitted in there perfect  :y
you can also angle the tweeter upwards a bit which improves things alot  :y
i cut some of the polystyreen away from the bck of the part where your elbow sits and glued the crossover unit in there  :y
Martin_1962
« Reply #3 on: 06 March 2009, 09:10:41 »
Thanks both
The front XOvers are in the arm rests
Will look at compatible 5 1/4s now
