Author Topic: traffic master retro fit?  (Read 7897 times)
nick v6
  • walsall / west midlands
Re: traffic master retro fit?
« Reply #15 on: 05 March 2009, 09:54:48 »
just looked on my radio its an sc 806
gav mv6
  • leicestershire
    • m/f irmscher mv6 lpg
« Reply #16 on: 05 March 2009, 18:15:46 »
ive had the tm removed from my car now if any needs it ?
Dam its hard work getting to 250 posts .......
« Reply #17 on: 07 March 2009, 14:06:56 »
right, this is what i have, courtesy of Nicks  egay link (thanks Nick)
Where do the plugs go etc?
    • 530D M Sport, 330i Coupe
« Reply #18 on: 07 March 2009, 14:29:43 »
If that's the actual one and you want it to fit your Omega with a 2015 it has the wrong loom and the Tm Button is for a Vectra B
The two exta wires + pins you need are to pass the Audio in / 0V back to the connector that you plug the cars loom into otherwise you won't have any sound from your telematics or phone prewiring.
« Last Edit: 07 March 2009, 14:32:17 by VXL_V6 »
nick v6
« Reply #19 on: 07 March 2009, 15:19:27 »
you have to move 2 wires for the telephone
speak to dave dnd for more information
« Reply #20 on: 07 March 2009, 16:18:09 »
Looks like a 26way iso lead from pic.  Gonna need a big hammer to get that into your 36way iso radio...
On the upside, the 26way ones are fully wired, unlike the 36way ones, so the phone signal would be passed through, if the loom fitted  :-X
nick v6
« Reply #21 on: 07 March 2009, 16:20:06 »
i spoke to dave dnd because if i pressed the tm button it would just mute the stereo
he told me the telephone wired had to be moved
« Reply #22 on: 07 March 2009, 16:26:26 »
Yours is a different head unit entirely.
NCDC series is a 36 way ISO, the bottom 16 connections are broadly similar (couple of changes around the remote power and diags lines), but the top 20 way connector bears no resemblence at all to the top 10way connector in yours, both physically or electrically. ;)
« Reply #23 on: 07 March 2009, 17:58:12 »
right ok. Tbh i took a punt as it was only a tenner. Thought that wat ok for the money just for the module? But i still need the correct loom then. Anybody got one? :-)
« Reply #24 on: 07 March 2009, 18:08:53 »
You will need to butcher that loom, plus a 36 way one, then still add 2 wires iirc.
« Reply #25 on: 07 March 2009, 18:53:40 »
Quite a difficult loom to get hold of, if you buy the Autoleads loom to connect a Parrot car kit to a Siemens HU Omega you should be able to make it up quite easily.
Failing that, if you aren't using the phone pre-wiring then you could utilise that as it has all the connections you need and is a bit easier than trying to tuck the loom behind the HU, you'll just have to extend the TM button loom
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #26 on: 09 March 2009, 15:10:49 »
Same problem I had Chris.
I've grafted the TM loom into the car body loom.
I used this diagram for the connections from the TM wiring.
Three wires need to be cut on the car loom they are pin 34 (on the back of the radio connector) black (mute line), pin 35 blue (phone audio) and pin 36 brown (audio ground). These three need to be cut and the six wires in and out of the TM box pieced into them.
On car body side, brown to brown/blue, blue to orange/blue and black to pink/blue.
On the head unit side brown/red to brown, orange/red to blue and pink/red to black. you then need to tap into the brown earth wire (pin 4) and I think I used the red (pin 2) for the black 0V and yellow 12V supplies ( don't cut these just tap into them).
TuBy's new whipping boy.
