Author Topic: omega b pre facelift rear shelf speakers  (Read 2573 times)
tunes
  • essex
« on: 08 March 2009, 20:24:51 »
i wanna tap the blank holes out and fit some rear speakers
are they 6.5"? and also is there a loom i can patch them into?
many thanks for any help people
IF I WANT TO GO IN A STRAIGHT LINE, IL BUY A FORD
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: omega b pre facelift rear shelf speakers
« Reply #1 on: 08 March 2009, 20:31:45 »
No Speaker wiring in the parcelshelf unless the car has BOSE
will have to run speaker wires into the boot
tunes
  • essex
« Reply #2 on: 08 March 2009, 20:44:09 »
where can i run them from?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 08 March 2009, 21:07:01 »
you will have to run 2x Pairs to the HU from the boot
Phil B
  • South Wales
« Reply #4 on: 09 March 2009, 23:43:54 »
Hi tunes, this relates to my current project
I'm just fitting some subs to my shelf, as I believe the bose system locates a pair of subs here, and I don't have room in the boot for a proper sub unit. They are 6 1/2" cut outs, just snip the blank rounds out with some tin snips and a screwdriver for leverage.
I got hold of an Impedance matcher from CPC which I'm going to wire in parallel with the rear door speaker feeds up behind the head unit. From here I was going to wire a long stereo RCA lead to the rear shelf along with power from the battery and fit an amp, which then supplies the shelf speakers.
I was planning to use the low pass switch on the amp so the speakers I fit to the shelf are reinforcing the bass section, hopefully the shelf won't vibrate too much.
Is this something similar to what you're after?
gstylebaby
  • stockport
« Reply #5 on: 10 March 2009, 04:59:53 »
Sound dead the shelf then you wont get as much vibration and i think i'm right in saying much more punch. :y
