Author Topic: Fitting rear electric windows on gls facelift?  (Read 2913 times)
stemon
« on: 20 March 2009, 13:51:12 »
hi guys any idea how to do this as there is no loom in place? i have all motors and door looms installed now just need to wire them up?
any help would be great as im puzzled
Re: Fitting rear electric windows on gls facelift?
« Reply #1 on: 20 March 2009, 13:55:16 »
So, when you fitted the door looms and plugged them into the B post sockets, were all the wires in the B post there?
stemon
« Reply #2 on: 20 March 2009, 14:10:38 »
 Hi Mark Nope there is about 4 wires missing on the car loom running to rear doors. ive done an ex plod which plugged straight in no prob, but not much luck on this :)
stemon
« Reply #3 on: 20 March 2009, 14:12:27 »
im guessing i need a live and earth to each door and need to add the switch control wires but need to work out where to wire these to.
« Reply #4 on: 20 March 2009, 14:12:54 »
How many wires are you short on the large IDC type connector on the main control switch for the drivers door?
There should be about 20 ish
4 wires is the exact number used by the windows!
« Reply #5 on: 20 March 2009, 14:16:14 »
Well the red wire goes to fuse F35
The brown black wires connect to pin 24 on the central locking ecu
The final 2 wires from connect to the drivers door main switch.
stemon
« Reply #6 on: 20 March 2009, 14:33:42 »
thanks mark you are a star , that sounds easy enough , where about is the central locking ecu? is it the one in drivers footwell
« Last Edit: 20 March 2009, 14:34:54 by stemon »
« Reply #7 on: 20 March 2009, 14:46:11 »
Yep, behind the drives side kick panel
« Reply #8 on: 20 March 2009, 14:53:35 »
i thought all facelifts had leccy windows in the back, except x-plod.
Years ago we had a 99 plate facelift on loan, gls spec, which had leccy rear windows
hotel21
  • The Kingdom of Fife
« Reply #9 on: 20 March 2009, 18:23:18 »
[movedhere] Omega General Help [move by] hotel21.
stemon
« Reply #10 on: 20 March 2009, 20:01:03 »
right an update, red , earths , brown and black are all connected.
now i have a problem ive got the two switch ones left  grey/green  and blue/red  but where do they go? ive connected them to the same colours on drivers door loom and the back switch operates the passenger front window?  help lol  ;D
stemon
« Reply #11 on: 20 March 2009, 20:03:33 »
forgot to say, if i connect the blue/red to perm live it makes the rear window go up only on its own.
« Last Edit: 20 March 2009, 20:04:01 by stemon »
Page created in 0.025 seconds with 20 queries.
