Author Topic: Phone prewiring relay required?  (Read 3378 times)
Phil B
  • South Wales
« on: 25 March 2009, 13:55:08 »
Hi all
I've got a Parrot ck3100 to fit but I don't want to spend 38 bucks on /can't wait for delivery of the autolead, so I want to solder the parrot's connectors in properly to the pre-wire cable.
My concern is there is a relay listed for my application, can anyone tell me what this is for and where it should be located?
Cheers
Phil
Phil B
  • South Wales
Re: Phone prewiring relay required?
« Reply #1 on: 25 March 2009, 13:56:24 »
Car is a 98 mini-facelift with CD500
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 25 March 2009, 15:44:50 »
TuBy's new whipping boy.
Phil B
  • South Wales
« Reply #3 on: 25 March 2009, 16:20:52 »
Thanks mate I'll have a look when I get out of work. Does anyone know what it does in case I haven't already got one?
It isn't required when you fit the parrot using the ISO looms, but they seem to connect up the same as the prewire in a roundabout way.
Phil B
  • South Wales
« Reply #4 on: 25 March 2009, 16:48:39 »
Just found this info:
VAU01REL - Vauxhall Telephone Solid State Relay
Original Vauxhall voltage regulator
• For Pre-wired vehicles without relay
• Prevents car kit overdriving head unit.
Still none the wiser
Phil B
  • South Wales
« Reply #5 on: 26 March 2009, 22:59:51 »
Just for future reference as far as I have worked out it's not a relay, but the actual coupling transformer for the audio feed to the stereo from the hands free. I guess if this is not there then the audio in at the prewire plug under the glove box will not be connected, so you would have to intercept the ISO leads behind the stereo.
As the parrot kit claims it is good enough to be connected straight to the stereo in this way I guess the "relay" is just an element of protection included by vauxhall, however it's presence being essential to connect the prewire audio in to the stereo loom audio in.
My car already had it anyway :)
I fitted the parrot to the prewire loom without removing the centre console and without the autoleads adaptor. I had to use a multimeter and common sense to work out the prewire colours / pin assignments as all the pinout diagrams I found simply reference the pin numbers of the VDA and not wire colour.
An old 4 pin pentium 4 power connector fits the power socket on the parrot, soldered to the 12v, ignition indicator and 0v on the prewire loom (red, black and brown).
As for the mute and audio connector I had to use the included parrot ISO lead as it contains some sort of logic circuit to interface the mute signal (pull up or down I guess). So the mute wire from there soldered to the other black on the prewire loom, and the audio signal and ground to the twisted blue and brown wires with stripes (that feed the coupling transformer under the steering wheel).
I now get the stereo muted and 'PHONE' on the display, with audio routed through the stereo to the front speakers, volume controllable with the steering controls. All proper and everything.
Hope this is of help to someone in the future!
Phil
« Last Edit: 26 March 2009, 23:09:00 by phil65412 »
