Author Topic: rear fog lights  (Read 3428 times)
rod
  • bristol
rear fog lights
« on: 24 March 2009, 18:24:15 »
hi ta you all i have an omega 2.2[wreg] my rear fog lights dont work checked fuse [fine] had a tester on back of switch [all fine] but no power to rear lights also buzzer on light switch dont work are there amy relays under the dashboard or can anyone please give me pointers in the right direction to solve this problem thanks to all that read this post rod
Re: rear fog lights
« Reply #1 on: 24 March 2009, 18:33:43 »
Put your question in "General Help" mate, you`ll get more response. This section is for members pics :y
Re: rear fog lights
« Reply #2 on: 24 March 2009, 19:27:31 »
Did you have your side lights or dipped beam on whilst testing.  As Fog lights only work with certain lights on.
hotel21
  • The Kingdom of Fife
rear fog lights
« Reply #3 on: 24 March 2009, 21:13:11 »
[movedhere] Vauxhall Omega Gallery [move by] hotel21.
Re: rear fog lights
« Reply #4 on: 25 March 2009, 08:14:12 »
And do you have a tow bar
over50now
  • Hertfordshire
Re: rear fog lights
« Reply #5 on: 26 March 2009, 05:43:29 »
Dunno if this helps. But for my rear fogs to be on, have to have front fogs on also.
IAM & ROSPA Gold Grade driver
oceansoul
  • Sunbury on Thames - Surrey
Re: rear fog lights
« Reply #6 on: 26 March 2009, 18:14:01 »
Mine dont. Side lights on- then either front or rear or both fogs will work.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: rear fog lights
« Reply #7 on: 26 March 2009, 18:29:36 »
Same here  ... sidelights then either front or rear or both :y
« Last Edit: 26 March 2009, 18:30:27 by Mark38 »
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: rear fog lights
« Reply #8 on: 26 March 2009, 18:41:18 »
same on my'n too Sidelight/HID's on then either switch
some weird thing with the omega ive noticed is if you turn the lights off with the fogs on the front come back on when you turn the switch on but the rears dont!! :(
Re: rear fog lights
« Reply #9 on: 26 March 2009, 18:56:48 »
To protect the poor buggers behind you a week after the last bit of morning mist!
I've pulled up along side people & told them they still had their rear fogs on, they're either oblivious or 'I wondered what that light was for' ....  :-?
« Last Edit: 26 March 2009, 18:57:02 by Andy_B »
Agemo
  • Cleethorpes
  • Insignia
Re: rear fog lights
« Reply #10 on: 26 March 2009, 23:38:51 »
The power to the rear fogs is via wires on the boot N/S "Hinge arm", and they are prone to snapping. Have you checked that cluster?   ::)
Martin_1962
Re: rear fog lights
« Reply #11 on: 27 March 2009, 16:42:25 »
I had a nightmare - broken wire in the hinge area and inside the car somewhere.
Ran a new lead from fuse to cluster
