Author Topic: a big thanxs  (Read 2494 times)
rod
  • bristol
a big thanxs
« on: 28 March 2009, 10:19:06 »
thanxs to every one who had suggestions on my rear fog lights but no luck with them no broken wires that i can see so looks like it has to go to an auto electrician [does any boby know of a good reliable company in bristol area that i can trust with my car] thanxs all
Agemo
  • Cleethorpes
  • Insignia
Re: a big thanxs
« Reply #1 on: 28 March 2009, 12:00:18 »
Shame to give up at this stage, you have power to the switch, but not to the lamp, there is only a piece of wire between the two.  ::)
« Last Edit: 28 March 2009, 12:00:38 by Agemo »
partsman
  • Market Harborough
  • Your friendly local parts man
Re: a big thanxs
« Reply #2 on: 28 March 2009, 17:29:14 »
I dont recall seeing an answer to the question regarding towbar fitment?
rod
  • bristol
Re: a big thanxs
« Reply #3 on: 29 March 2009, 16:03:19 »
hi no towbar fitted yet still puzzled over these rear fogs regards rod
Re: a big thanxs
« Reply #4 on: 29 March 2009, 18:52:27 »
Does the loom in the boot still have the bridging loop plugged in? You'll find a plug (I think yours is round-ish with all the wiring ready to go for the trailer electrics) and there should be a blue/black wire making up the circuirt. You have to remove the trim piece from across the back edge of the boot to get to the loom.
rod
  • bristol
Re: a big thanxs
« Reply #5 on: 31 March 2009, 21:27:39 »
hi yes mine has the plug in the boot under the trim and it has a blue/black wire i put electrical teseter on the wie and it lights up when you turn rear fog light switch on and goes out when i switch rear fog light switch off so i pressume i got power to that [so between this and rear fogs must be a break in wire somewhere so i wonder if i used a scotch clip and a piece of wire i could wire up my rear fogs [what do you reckon am i going about this right regards rod
