Pages: [1] 2 3  All   Go Down
Author Topic: Bloody speaker  (Read 10936 times)
Bloody speaker
« on: 30 March 2009, 18:33:14 »
More of a rant than anything  >:(
I have had this intermittent problem for over 5yrs.  Intermittent drivers door speaker no sound.
Changed the speaker no end of times, can't believe they are all faulty.
Its too intermittent to be able to trace the problem in the loom (HU swapped a few times as well, and a BOSE amp added).
Best to replace door loom first, is it easy to do?
iainb
  • West Midlands
Re: Bloody speaker
« Reply #1 on: 30 March 2009, 18:42:40 »
Ushall give away is intermitant function loss in other door systems
Check connector in A post for water ingress.
Re: Bloody speaker
« Reply #2 on: 30 March 2009, 18:45:33 »
A post connector is always dry and clean...
iainb
  • West Midlands
Re: Bloody speaker
« Reply #3 on: 30 March 2009, 18:49:48 »
Very well could be door harness maybe dry joint on one or more pins
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Bloody speaker
« Reply #4 on: 30 March 2009, 19:59:48 »
Rewire the speaker back to the amp??
Next doors BMW had a similar problem it turned out to be the wiring was chaffed and shorted out on the door  so a quick fix with heatshrink and he was a happy chappy
« Last Edit: 30 March 2009, 20:01:41 by tmx »
Re: Bloody speaker
« Reply #5 on: 30 March 2009, 20:06:31 »
Had same issue before I bosed it, so its either 4 or 5 duff speakers, 4 duff HUs, the door loom, the loom from door to kick panel, or kick panel to HU.
    • 530D M Sport, 330i Coupe
Re: Bloody speaker
« Reply #6 on: 30 March 2009, 22:16:48 »
My money is on door loom. If it was me i'd get hold of another loom as your going to remove the door trim, then that way you'll only do it once and eliminate it.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bloody speaker
« Reply #7 on: 30 March 2009, 22:39:07 »
Seen similar problems with door looms in Mk3 fiestas
Radio & Decoding Technician
www.dndservices.co.uk
GG
  • Milton Keynes
  • If kicking doesn't work, then hit it with a hammer
Re: Bloody speaker
« Reply #8 on: 30 March 2009, 23:12:44 »
I think door loom, but why replace. Just circuit test the speaker wire to inside the car in the kickwell and replace this short section of speaker wire only
Re: Bloody speaker
« Reply #9 on: 30 March 2009, 23:25:21 »
Trouble is that it is very intermittent so you're not garaunteed to find the fault. My thoughts are that if you've took the door card and plastic sheet off it's only a couple of plugs to remove the loom and you can swap the loom and remove that from the equation.
GG
  • Milton Keynes
Re: Bloody speaker
« Reply #10 on: 30 March 2009, 23:27:08 »
fair enough if you have a spare loom
Re: Bloody speaker
« Reply #11 on: 30 March 2009, 23:44:31 »
IF being the word!!  ;D
GG
  • Milton Keynes
Re: Bloody speaker
« Reply #12 on: 31 March 2009, 00:06:13 »
so my previous suggestion not so daft  ;D ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Bloody speaker
« Reply #13 on: 31 March 2009, 00:54:47 »
If it was me I'd replace to speaker wiring to the door piller.  :y
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Bloody speaker
« Reply #14 on: 31 March 2009, 07:17:45 »
Will be a lot easier with the rivited bottom panel removed, the one the airbag sensor sits in.
Pages: [1] 2 3  All   Go Up
