Author Topic: Error codes  (Read 1880 times)
charlie22
  • Swansea
Error codes
« on: 02 April 2009, 11:29:55 »
Using the Auto Scanner Opel CAN I have the following error codes
 Which code to talcke first?
P1555: Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load - Not Present The control unit recognises the malfunction of the circuit via an internal evaluation logic.
Concerned Terminals:
3, 10, 13, 20, 26, 30, 42, 45, 58, 62 (X58)
P0170: Lean Exhaust - Present
Air/fuel mixture constantly too lean
19 (X58), 35 (X58), 57 (X58)
P0130: O2 Sensor 1 Circuit Voltage Low - Not Present
The voltage at the control unit input (terminal 57 (X58) ) is temporary too low.
The fault is stored directly on recognition.
P0130: O2 Sensor 1 Incorrect Signal - Not Present
P0302: Cylinder 2 Misfire Detected - Not Present
Too many misfires detected by the crankshaft position sensor
31 (X58), 63 (X58)
This after removing the error codes
SVS-request from Transmission Control Module
Thanks Nigel
Re: Error codes
« Reply #1 on: 02 April 2009, 11:33:41 »
It has symptoms of the cam sensor causing trouble for a 2.2.....although lacking the cam sensor fault code.
Re: Error codes
« Reply #2 on: 02 April 2009, 19:34:37 »
Worth checking whats in gearbox ecu as well.
