Author Topic: Bl**dy keyfob  (Read 3308 times)
Martin_1962
Bl**dy keyfob
« on: 08 April 2009, 19:55:28 »
Went to use one and it jammed on. :-/
Popped off key cover and then it switched off.
Locking switch going down and it is only 18 months old. :(
Then check carefully, the cover has lost its elasticity, the switch is slightly weaker so doesn't like to push back >:(
Then while replacing the switch, part of the track lifted >:(, jumper wire fitted. Small blob of alraldite holding it on.
Looks like I need to try my new button manufacturing experiment sooner rather than later. :o
Martin_1962
Re: Bl**dy keyfob
« Reply #1 on: 08 April 2009, 20:35:39 »
Worked out the stiff cover probably killed the switch :(
nick v6
  • walsall / west midlands
Re: Bl**dy keyfob
« Reply #2 on: 09 April 2009, 09:09:05 »
have you had any more thinking time over changing the little switch in my key fob
its the type where its i big button and a small button on the side of the key
if you can give me rough price i can get the key and cash to you
thanks
Martin_1962
Re: Bl**dy keyfob
« Reply #3 on: 09 April 2009, 11:19:26 »
thanks
Still haven't seen the inside of it to know which switch
Re: Bl**dy keyfob
« Reply #4 on: 09 April 2009, 11:53:49 »
If its infra red one then I have a donor fob you can have to rob bits from.....
nick v6
Re: Bl**dy keyfob
« Reply #5 on: 09 April 2009, 12:02:50 »
shall i post my key to martin then
Re: Bl**dy keyfob
« Reply #6 on: 09 April 2009, 18:02:13 »
sounds like IR one...
