Author Topic: sat nav no sats  (Read 23181 times)
nick v6
  • walsall / west midlands
Re: sat nav no sats
« Reply #15 on: 19 March 2009, 22:03:15 »
so how do i change then
it wont let me adjust the active levels
yes it will - it checks the current levels when you do the set, and uses that value
how can i change the levels
Re: sat nav no sats
« Reply #16 on: 19 March 2009, 22:14:08 »
service menu - SET ACTIVE LVELS
nick v6
Re: sat nav no sats
« Reply #17 on: 19 March 2009, 22:22:05 »
i do that and it wont let me change them :-/
i aint sending the unit back till monday as the chap aint around till tuesday
« Last Edit: 19 March 2009, 22:22:39 by nickandann »
Re: sat nav no sats
« Reply #18 on: 19 March 2009, 22:23:22 »
Read what I said above.
nick v6
Re: sat nav no sats
« Reply #19 on: 19 March 2009, 22:24:44 »
ok ill change them round in the morning and ill let you know how i get on :y
nick v6
Re: sat nav no sats
« Reply #20 on: 20 March 2009, 09:38:58 »
went to service menu and then set active levels
and it won't let me change them
i can highlight each one but won't let me change it
ive tried changing the levels with the engine running and with just the ignition on
and still nothing
Re: sat nav no sats
« Reply #21 on: 27 March 2009, 18:29:16 »
and still nothing
thats normal - it senses the current levels at he point you hit the button to set them.
nick v6
Re: sat nav no sats
« Reply #22 on: 27 March 2009, 19:19:24 »
so if i drive forward then hit the buton it will change that and the same with the lights
still dont understand what that has to do with the hw failure and not getting and satalites :-/
Re: sat nav no sats
« Reply #23 on: 27 March 2009, 19:53:21 »
right, lets start from scratch.
Are you getting speed pulses in Service > External I/O when moving.
nick v6
Re: sat nav no sats
« Reply #24 on: 27 March 2009, 21:33:58 »
yes im getting speed pulses
it shows what speed im doing
Re: sat nav no sats
« Reply #25 on: 27 March 2009, 21:42:51 »
OK, is the direction (same menu) correct (FWD, changing to REV when Reverse selected)
nick v6
Re: sat nav no sats
« Reply #26 on: 27 March 2009, 21:44:22 »
it used to say froward when going forward and reverse when reversing
it dont now
same as the lights
all working backwards now
Re: sat nav no sats
« Reply #27 on: 27 March 2009, 21:46:14 »
Does it go to FWD when you put it in reverse?
nick v6
Re: sat nav no sats
« Reply #28 on: 27 March 2009, 21:47:43 »
it says rev when goin forward and shows the speed in -
never checked to see if it changes if i go in reverse
Re: sat nav no sats
« Reply #29 on: 27 March 2009, 21:49:38 »
check when you get a mo...
