Author Topic: sat nav no sats  (Read 23045 times)
nick v6
  • walsall / west midlands
Re: sat nav no sats
« Reply #30 on: 27 March 2009, 21:50:46 »
will do in the morning when i take ann to work and i'll let you know what happens
ill go in reverse all the way to her work
not sure if the police would take to kind to that
nick v6
Re: sat nav no sats
« Reply #31 on: 28 March 2009, 07:18:33 »
checked it all
tried to change all the settings while driving down my street in rev and nothing
still says rev no matter what direction i go :'(
Re: sat nav no sats
« Reply #32 on: 28 March 2009, 13:02:05 »
checked it all
Right, double check that connection in the footwell.  It should say FWD for all gears except R.
nick v6
Re: sat nav no sats
« Reply #33 on: 28 March 2009, 15:16:04 »
checked it all
tmx is popping down during the week
ill check the connections and see how i get on
Re: sat nav no sats
« Reply #34 on: 28 March 2009, 15:53:40 »
checked it all
Thats good - someone who knows the system enough to be able to diagnose stuff on it :y
nick v6
Re: sat nav no sats
« Reply #35 on: 09 April 2009, 09:12:24 »
no word off tmx now for ages so on friday while ann has the day of work ill be doing the sat nav myself
ive decided i'm going to use the wires at the back of the radio and do it that way
and run an extra wire for the reverse
ive taken my traffic master out but left the wiring loom at the back of the radio in so i will use that to connect to the sat nav
hopefully it will work
Re: sat nav no sats
« Reply #36 on: 09 April 2009, 18:01:26 »
easier to pick up from passenger footwell plugs. Much easier.
Also, you may want tm again... ;)
nick v6
Re: sat nav no sats
« Reply #37 on: 09 April 2009, 18:03:14 »
tried that and it not worked lol
Re: sat nav no sats
« Reply #38 on: 09 April 2009, 18:04:55 »
check, double check, tripple check its right.  Then blame either the unit or the gps.  Connections at radio will be no different.
Which one was it not picking up? FWD/REV? Got a speed pulse on it?
nick v6
Re: sat nav no sats
« Reply #39 on: 09 April 2009, 18:06:54 »
ive got a speed pulse but only reverse works
lights are weird
the screen lights up with my lights on but the display say lights off but i think i can change the active levels for that
i cant change the active levels for the forward/reverse
Re: sat nav no sats
« Reply #40 on: 09 April 2009, 18:09:54 »
lights are weird
you set active levels for rev and for lights.
Does it always say rev, or does it say FWD when reverse is selected?
Display should DIM when lights switched on.
nick v6
Re: sat nav no sats
« Reply #41 on: 09 April 2009, 18:11:23 »
lights are weird
it says reverse all the time and counts the speed in -
yes display does dim when i set the active levels correct for screen
just cant set active levels for forward/reverse
Re: sat nav no sats
« Reply #42 on: 09 April 2009, 18:45:53 »
lights are weird
so its just rev wire that needs fixing then. no point pissing with radio for that.
no sure it'll resolve you prob though, if you're getting speed pulses
nick v6
Re: sat nav no sats
« Reply #43 on: 09 April 2009, 18:47:00 »
so ive just gotta check the reverse wire then
Re: sat nav no sats
« Reply #44 on: 09 April 2009, 18:52:23 »
if you are getting speed pulses (should register 10 or so even at walking pace)
