Author Topic: ncdc 2013 cd making an awful noise  (Read 3373 times)
johnnycboy
  • Colchester
« on: 11 April 2009, 20:55:35 »
(THE ELITE) Just gone to use the cd in the car and pressed number # on keypad to load a different disc and it started to make an awful noise, as though something is grinding inside - needless to say I get cd error and cannot get the disc magazine to eject.  Is it a breaked ncdc now or something simple to repair.
(THE CD) My cdr 2005 comes up with error cd, I'm assuming someone before me has been playing discs they shouldn't have been - is this another breaked cd player.
On both counts TIA
« Last Edit: 11 April 2009, 20:56:43 by johnnycboy »
Re: ncdc 2013 cd making an awful noise
« Reply #1 on: 12 April 2009, 11:55:02 »
its quite common for the magazines/discs to jam on these.  Solution is to remove Changer portion, pop the lid from CD Changer part, under a couple of small screws that have the bar over the magazine, then remove the 4 screws that hold the mag together, and get all the bits out.
it's likely the corner of mag may be damaged, and if the cd that jammed isn't cracked, I'd be surprised...
johnnycboy
  • Colchester
« Reply #2 on: 12 April 2009, 14:33:14 »
Just got the mag out, believe it or not the disc was not jammed.  put it all back together without a disc in and its still making a noise.  do i need to source a new cd changer part then.
« Reply #3 on: 12 April 2009, 15:36:03 »
Sounds that way. See the vertical board mounted along side changer mechanism - you need to use that, not the one in the replacement changer.
And if you're lobbing the old changer away, do so in my direction, handy to strip for spares ;)
johnnycboy
  • Colchester
« Reply #4 on: 12 April 2009, 15:52:55 »
will do TB :y
johnnycboy
  • Colchester
« Reply #5 on: 13 April 2009, 09:40:15 »
Will a ccr 2006 CD innards work inside the NCDC 2013 :question
« Reply #6 on: 13 April 2009, 10:22:38 »
Yup, though as previously said, you need to use your old vertical board, not the ccr one
johnnycboy
  • Colchester
« Reply #7 on: 13 April 2009, 13:15:03 »
cheers TB :y
johnnycboy
  • Colchester
« Reply #8 on: 16 April 2009, 20:57:50 »
have just seen this clicky
Can it be used for my ncdc cd and is it worth 75 notes
All advice appreciated
    • 530D M Sport, 330i Coupe
« Reply #9 on: 16 April 2009, 21:16:50 »
Yes it could but I don't think i'd want to pay £75 for it....
johnnycboy
  • Colchester
« Reply #10 on: 16 April 2009, 21:18:45 »
perhaps i will give that a miss then.  thanks vxl v6.
« Reply #11 on: 16 April 2009, 21:23:45 »
Also keep a look out for CDC-3 on Ebay.
Have to say that a lot of CDC-3's and CCR2006's seem to have ridiculous buy it now or starting prices on Ebay.
johnnycboy
  • Colchester
« Reply #12 on: 16 April 2009, 22:03:29 »
cdc3 went for 73 notes yesterday.  running out of options at the moment.  need to get the cd back.  radios doing my head in.  having said that started listening to radio 2 (i must be getting old :-[) and enjoying it ;D
