Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: bose system swapout  (Read 18415 times)
Re: bose system swapout
« Reply #60 on: 02 April 2009, 19:38:03 »
You need to go into the NCDC2013 with Tech2 and select programming and the config programming.
Reset the varient code to:035 (it should be 034 at the moment)
Program that in and jobs a good un
NCDC2011/NCDC2013/NCDC2015 is the line I believe. Its the long one just under CCRT2008...
Kait
  • Tallinn, Estonia
« Reply #61 on: 02 April 2009, 19:40:20 »
Then i did it right, don't remember what the second no. was but the last one was 4 and I changed it 1 step up to 5....so its ok and I remember that disconnected speakers faults did not come up again after reprogramming.
Is there any chart or table available for omega with codes( I allready have it for displays) for ECC, Radio ect. for everything that can be code index programmed in with Tech2?
« Last Edit: 02 April 2009, 20:20:17 by kait »
« Reply #62 on: 02 April 2009, 21:10:22 »
If you have a Tech2, presumably you have TIS2000?  Its all in there.  It would be a big job to recreate all the programming options.
Kait
  • Tallinn, Estonia
« Reply #63 on: 02 April 2009, 21:25:00 »
Well, I have Tis2000 in my computer, haven't found them yet..... ::)
Where can I find them?
« Reply #64 on: 02 April 2009, 21:27:18 »
Service Info - Enter car details etc - all under General Car Info
Kait
  • Tallinn, Estonia
« Reply #65 on: 03 April 2009, 21:39:44 »
TIS gave me the following index codes for NCDC 2015:
1997-bose-025, no bose-024
2002-bose-045, no bose-044
I think I reprogrammed it from 024 to 025,
but it should be 045.
Should I let it be 025 or should I reprogram to 045? :-/
Does anybody know the difference in code index for bose between 1997 and 2002 version? :-/
« Last Edit: 03 April 2009, 21:53:24 by kait »
« Reply #66 on: 04 April 2009, 09:53:37 »
Not checked, but likely it depends on the actual hardware - Ident on the info screen on T2 when it first talks to the radio...
Kait
  • Tallinn, Estonia
« Reply #67 on: 09 April 2009, 23:23:06 »
Well, I have my bose all set up and working. I can't say it's the ultimete sound, but i'ts way better, much cleaner compared to the standard system.
Nice, crisp and clean sond.... :y
Money well spent :)
Kait
  • Tallinn, Estonia
« Reply #68 on: 18 April 2009, 08:32:32 »
can anybody give me a list of omega stereos that can be connected with Bose....from '94-'04?
Pages: 1 2 3 4 [5]  All   Go Up
