Author Topic: Parking Light Disconection ?  (Read 3271 times)
the_bed_wrecker
  • SUNNY HARTLEPOOL
  • Where's that stormtrooper gone ?
« on: 18 April 2009, 23:46:12 »
Who had the stupid idea of connecting the parking lights on the indicator stork ? and is there anyway of disconnecting it or making it so there is no power to it when the kays out, getting p*ssed of with flat battery in morning or having to go out at 1 at night to move the indicator stick !!
Cheers
TBW
Must be getting old to have one of these !!
Re: Parking Light Disconection ?
« Reply #1 on: 18 April 2009, 23:56:56 »
A lot of cars have it as started.  Certainly does away with having to but the light on the door glass and jam it in the window.
As for disconecting, sorry, I dont know.
I used to have the same problem with mine, now I go through a little routine as I get out.
Sunroof closed, Climate to off, side lights off.  Remove radio panel.  Then when I hear the cooling fans calm down, I do one final check for lights on the dash as I switch off and exit the car.
« Reply #2 on: 19 April 2009, 00:05:07 »
Cheers
TBW
Your battery must be on its last legs the if it can't hack a couple of 5W lamps being left on for a few hours, even if it was all night. Look at the car as you walk away after locking it. ;)
DC
  • Switzerland
« Reply #3 on: 19 April 2009, 18:50:21 »
I have noticed it is generaly German cars that have this feature. Does anyone know what's the reason?
« Reply #4 on: 19 April 2009, 19:20:58 »
As said earlier ... my 73 MK III Cortina did the same, but the Mk IV didn't  :-/
Slowmo
  • Sheffield/Chesterfield
  • 1998 mf/l 3.0
« Reply #5 on: 20 April 2009, 17:08:13 »
I traced out the two wires in the boot which go to the sidelights. ( they have separate wires).
I then connected a cheap mechanical buzzer between them. Any normal time, they are both at 0V or both at 12V only when one is on and one is off does the buzzer sound. (ie. when you forget the flasher stalk!)
If you can't find a mechanical buzzer, then a cheap electronic one will do, but you will have to feed it through a bridge rectifier, to keep the polarity correct. (both available from Maplin)
Peter.
« Reply #6 on: 20 April 2009, 17:17:45 »
On my car the  normal "lights-on" buzzer activates if you open the driver's door with the parking lights on.
I find them quite useful and leave them on whenever I'm parked in a street at night.  As said, a couple of watts of battery drain is neither here nor there
« Reply #7 on: 20 April 2009, 17:22:07 »
On my car the  normal "lights-on" buzzer activates if you open the driver's door with the parking lights on.......
Face lift cars only, whether it's all of them or not I don't know. My 99 preface lift just has a lights on buzzer for main/normal lights, as does SWMBO's 52 Astra cos there's no parking light on it!  ;D
« Last Edit: 20 April 2009, 17:22:44 by Andy_B »
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 20 April 2009, 18:43:13 »
My 2000 tractor has the lights on buzzer, but not for the parking lights.  ::) Actually I like the idea, but it seems an easy job to rig a switch.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #9 on: 20 April 2009, 19:40:16 »
My 98 Mini F/L beeps when the parking lights are on and the door is open
all sorts of cars have parking lights but VAG  / OPEL have them on most of there range
« Reply #10 on: 20 April 2009, 21:02:15 »
side lights or individual parking lights ie opperated with the indicator stalk? :-/ My 99 mini facelift definitely does't buzz with parking lights.  :y
