Author Topic: Removing the facelift climate control panel  (Read 5818 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 23 April 2009, 10:40:51 »
If you pull out the stereo and the heated seat switches, will the climate control panel slide out easily? or is there further work involved?
Re: Removing the facelift climate control panel
« Reply #1 on: 23 April 2009, 18:45:42 »
Have you looked here ....... http://www.omegaowners.com/forum/YaBB.pl?num=1152745540  :y  :y
MutantCav
  • Gainsborough
« Reply #2 on: 24 April 2009, 17:03:36 »
It arrived ok then mate? :y
  • Doha, Qatar
« Reply #3 on: 24 April 2009, 17:06:16 »
Yes I have. Problem is, it doesn't say whether the climate control unit slides out or not. It just removes the entire walnut effect fascia without a discussion on whether the climate control panel can be separated from the fascia.
Therefore I wanted to know whether after having removed the stereo and the heated seat switches directly below, if the climate control panel can be slid out?
  • Doha, Qatar
« Reply #4 on: 24 April 2009, 17:07:10 »
Yeah, guess what it turned up yesterday!
MutantCav
  • Gainsborough
« Reply #5 on: 24 April 2009, 17:08:21 »
Wow that really took its time!!! Sent it before my daughter was born I think?? She is 9 weeks old now!!
« Last Edit: 24 April 2009, 17:09:31 by ShieldOfSteel »
  • Doha, Qatar
« Reply #6 on: 24 April 2009, 17:09:56 »
Yeah, normally its not too bad. Customs probably decided to take a closer look. :)
iliak
  • Moscow Russia
    • Opel Omega B, X25XE
« Reply #7 on: 25 August 2017, 14:52:31 »
the question's still unanswered despite all these years. Does someone know the answer?
« Reply #8 on: 25 August 2017, 15:15:46 »
Radio out, two screws, ashtray out (one screw) and the centre trim comes out.
Free the two clips on each end of the panel and push towards the dash. Unplug the two electrical connections.
Refit in reverse and call it done.
Took longer to type ;)
« Reply #9 on: 25 August 2017, 15:17:13 »
Ps don't break the front off the radio or you'll be annoyed ::)
iliak
  • Moscow Russia
« Reply #10 on: 25 August 2017, 15:35:54 »
you're the best!
