Author Topic: Omega CCRT700 <<ERROR CDC>>  (Read 7036 times)
blubass
  • France
« on: 01 May 2009, 12:16:33 »
Hi there,
I have a couple of questions about an Omega mv6 ccrt700 cd charger.
I have no problem with the codes, as i followed the right procedure to enter it after having disconnected/reconnected the CD charger:
When I put CD in it, and I push on the "CD" button on the radio, it displays <<ERROR CDC>>.
When I remove the magazine, it displays <<NO MAGAZINE>>, so the communiction between the ccrt700 unit and the cd changer unit seems to be correct.
I opened the cd changer unit to have a look inside, all seems correct (no broken part, no cd in it).
I put cd in the box with the right side (labels upside). When introducing the 6 cd box, something moves and makes noise in the unit (cames, motor, ...), but it does not load any CD.
So, I assume that my cd changer unit is dead.
and here are the questions :
1°) Reading the different posts, it sounds that I have to purchase the exact same model (Blaupunkt CDC2). Could I have a confirmation here ? is there no way to purchase a new cd changer model, able to read MP3 CDs?
Here is the model I own :
2°) Looking at the place where the CD Charger is located, I can see an additional free (unused) cable (cord ?) with more pins that the cable currently connected to the unit, with some kind of coaxial cable near it :
Does anyone have an idea of what is this cable intended to ?
Do you think it could be possible to connect another unit than the CDC2 ?
Thanks in advance for the replies :)
markey mark
  • SLady bitshorpe north lincs
Re: Omega CCRT700 <<ERROR CDC>>
« Reply #1 on: 01 May 2009, 13:44:01 »
thats for a fone kit bud ! :y
none of the cd changers like mp3s for too long !
yes you will have to get one from a ccrt700 system  :y
« Reply #2 on: 01 May 2009, 14:52:58 »
CDC2 wont read MP3's at all.....its a CD player and wont support MP3 encoded discs
    • 530D M Sport, 330i Coupe
« Reply #3 on: 01 May 2009, 21:45:37 »
The coaxial cable is probably for a GPS module for the optional OnStar element of the CCRT700.
blubass
  • France
« Reply #4 on: 03 May 2009, 09:29:44 »
Thanks for the info guys.
Thus I forget the possibility of reading mp3s with the ccrt700, which is not a big problem, I'll just have to burn CDs  ;).
Also, I unsderstand that I have to purchase the same replacement CDC2 CD unit.
Does anyone here use the phone function of the ccrt700 ?
I'd like to use the sim card of my gsm phone, however it is much too small, as the sim card for the ccrt700 shoud be in a "credit card format".
Any hint ?
blubass
  • France
« Reply #5 on: 03 May 2009, 09:34:18 »
Oh, an additionnal question :
I must purchase a new CDC2 unit. I thint that, ordering it in a garage, I would pay 3 or 4 times the price... :(
Any idea of a place to buy this unit, online ?
Thanks again
« Last Edit: 03 May 2009, 09:34:41 by blubass »
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 03 May 2009, 12:10:36 »
blubass try PMing Elite Pete Or Looknee they break lots of elites so will problably have a CCRT700 CDC2 changer for a good price!
« Last Edit: 03 May 2009, 12:10:47 by tmx »
« Reply #7 on: 03 May 2009, 19:19:10 »
For phone side, not a bad phone, but GSM900 only, so voda or o2.
Both will give you free sim cards, but that means another number...
  • Online Online
« Reply #8 on: 04 May 2009, 19:18:53 »
Any hint ?
A new SIM comes attached to a full sized/credit card sized card, you just don't press/push it out!  ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 04 May 2009, 19:21:39 »
Couldn`t you simply Clone a SIM card ? As long as you turned off your mobile when in the car so that only one was active, surely that would work?
Radio & Decoding Technician
www.dndservices.co.uk
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 04 May 2009, 19:23:10 »
Any hint ?
Large SIM card adaptors are readily available for not a lot -  :y
  • Online Online
« Reply #11 on: 04 May 2009, 19:26:27 »
Any hint ?
Or a full sized card where the small SIM has been removed .... and a bit of sticky tape!!  ;D  ;D  ;D  ;D
