Pages: [1] 2 3  All   Go Down
Author Topic: Re: CD-SAFE (CCRT700)  (Read 9238 times)
alexgundes
« on: 27 April 2009, 21:39:08 »
Switch on ignition,
Radio On
Select CD
Switch off CCRT700 with OI key.
Press hold CD,
Switch on CCRT700 with OI key, keep CD pressed until confirmation beep.
The display shows CD-Code for 3 secs
Then CDC Code ---- (10)
Enter Code
Confirm "OK" by press the muti-function control.
hi there i have the same problem.
well i will try to explain
my cd is not work and i buy another cd changer by philips for my opel vectra B
i do this steps in manual, but it appears CD-CODE, i wait 3 sencods and nothing do. don't appear the chanel for i can put the codes. Its possible to reset the codes? i need help please
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #1 on: 28 April 2009, 16:16:54 »
a phillips cd changer wont work with a CCRT700!
nor will it work in a radio in a vectra B as these use the CAR4/6XX series with a blaupunkt changer
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 28 April 2009, 17:46:59 »
Very important to get the right model of changer for your head unit, and rememeber that not all CDC2 and CDC3 units are the same either!
Look at the part number on the label, and replace with an IDENTICAL part number. If its different, it ain`t gonna work.
Radio & Decoding Technician
www.dndservices.co.uk
alexgundes
« Reply #3 on: 28 April 2009, 19:50:38 »
hi there. it's work fine in ccrt700 on star.
i have one and its work. the problem is:
i try many times de codes and the cd changer/ radio don't accept the code. so in this moment apeears CD-CODE, when i try to do again
almost i am waiting for 3 secs and next apeeats the CDC code ----, and then, i put the code. So this last message don't appers im car.
wha i can do?
i try to put the key in car, and waiting 2 hours to resolve
please help me
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 28 April 2009, 20:09:00 »
as DaveDND said please list your CD Changers model number and we can then confirm if its compatible with the CCRT
if its not you wont be able to decode it as the CCRT uses a special changer
alexgundes
« Reply #5 on: 28 April 2009, 20:13:57 »
ok
Philips 326599176
No. 09192429
Type CDC3
W1G
Made in Hungary
BS070302
22dc075/78
gmcdc320021158
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 28 April 2009, 20:19:18 »
you will have to wait for The Boy to read this as im on the understanding the CCRT700 only works with a special Blaupunkt CDC2 but The Boy know's a hell of alot more than i do about this so will await his wisdom
« Last Edit: 28 April 2009, 20:19:39 by tmx »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 28 April 2009, 22:53:35 »
I have not seen the CDC3 work with a CCRT700 myself
Unless anybody else knows different?
alexgundes
« Reply #8 on: 28 April 2009, 23:16:05 »
this is my car radio
and this is a CDC3
« Last Edit: 28 April 2009, 23:18:45 by alexgundes »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 28 April 2009, 23:45:12 »
Sorry should have said
I have not seen a CODED CDC3 work with a CCRT700 myself
alexgundes
« Reply #10 on: 29 April 2009, 00:49:16 »
Its Works well.
I had my operation, but broke down and had to buy another CD-changer. I put the code several times, and than this error i have appears.
When i not resolve this problem. the cd changer not go work until i resolv and put the correct code. That i put a message in forum to know if was possible to reset all that codes, and start again.
i have try many things. someone tell to put the car key in ingnition and stay for 30 mins or 2 hours, today i leave for 7 hours and nothing do.
i'am affraid to go a office opel and they says me the car must go to a europe officer assistance.
i will  trying everthing.
« Last Edit: 29 April 2009, 00:54:32 by alexgundes »
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #11 on: 29 April 2009, 15:55:34 »
that changers part number is for a CCR600 setup not a CCRT the CODE WILL NOT BE ABLE TO BE INPUT! the changer is the wrong one there are 4 different CDC3's you need one that come of a car with a CCRT700
when you get a CCRT700 CDC3 changer it might not even ask for the code or it will and you will be able to input it
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 29 April 2009, 16:20:20 »
We have encountered 9 so far across the Vauxhall, Opel and Holden range
You need to make sure you get the right one.
« Reply #13 on: 29 April 2009, 16:40:49 »
Isn't it a CDC2 that's used with a CCRT700?  :-/
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #14 on: 29 April 2009, 16:41:52 »
Nah andy i thought that so spent an hour last night googling
Astra G & Zafia A had the CCRT700 & CDC3 setup as an aptional extra there were other vauxhalls this went in aswell
there are as dave said atleast 9 different CDC3s about so there is a "special CCRT" variant like there is with the CDC2
« Last Edit: 29 April 2009, 16:42:41 by tmx »
Pages: [1] 2 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
