Pages: 1 [2] 3  All   Go Down
Author Topic: Re: CD-SAFE (CCRT700)  (Read 9262 times)
« Reply #15 on: 29 April 2009, 16:53:16 »
Nah andy i thought that so spent an hour last night googling
Astra G & Zafia A had the CCRT700 & CDC3 setup as an aptional extra there were other vauxhalls this went in aswell
there are as dave said atleast 9 different CDC3s about so there is a "special CCRT" variant like there is with the CDC2
I'll look tonight whenI get home, I've posted pictures of what I've got in mine ......  :-/
alexgundes
« Reply #16 on: 29 April 2009, 16:56:33 »
hi there i thing my problem is another.
i put many times the code, and the radio ccrt700 was blocked. need do  decoding epprom for the cd canger work again.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #17 on: 29 April 2009, 17:07:26 »
our Astra CDX has a CCRT but no changer so i should really bodge an omega one onto it but i dont have the time :-[
telephone works though!! :y :y
« Last Edit: 29 April 2009, 17:08:14 by tmx »
« Reply #18 on: 29 April 2009, 17:13:48 »
http://www.omegaowners.com/forum/YaBB.pl?num=1236201616
CDC2!  :y
and I think I posted my picture there too ...... at work so can't see it.  ;)
« Reply #19 on: 29 April 2009, 23:19:35 »
Just looked .... & I didn't.
So here's the sticker from the bottom of my CDC2 that talks to my CCRT700  :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #20 on: 29 April 2009, 23:22:44 »
same as my Mv6s is that out the Ashtray or the Omega?
« Reply #21 on: 29 April 2009, 23:43:05 »
Omega 99 Elite.  :y
alexgundes
« Reply #22 on: 30 April 2009, 00:43:19 »
ok
but in my case is a CDC3 and works fine.
the problem is another, i put many times the code and the radio is block a CDC need so decoder radio for accept again my cdc3
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #23 on: 30 April 2009, 01:25:47 »
radio locked now?
is it saying CD-SAFE? or just SAFE??
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #24 on: 30 April 2009, 09:26:02 »
CDC3 when used with the CCRT700 does not require a code.
If it is asking for one, then it is either the wrong changer or is faulty.
Radio & Decoding Technician
www.dndservices.co.uk
alexgundes
« Reply #25 on: 02 May 2009, 18:53:28 »
radio locked now?
the radio is SAYING CD-SAFE. NOT safe.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #26 on: 02 May 2009, 22:19:21 »
as dave has already said you have the Wrong CDC3 you need one from a CCRT Equiped car not any old CDC3
« Last Edit: 02 May 2009, 22:20:07 by tmx »
alexgundes
« Reply #27 on: 03 May 2009, 22:20:58 »
Maybe i'am not explain well.
look i am not the wrong CDC3, My car had one CDC3 and its work very well. the problem was, my cdc3 was broken and i buy another one.
I'am not saying is wrong or not, but i garantie that works
« Reply #28 on: 04 May 2009, 09:58:54 »
OK, seems to be some confusion here, based around the fact that all UK spec Omegas factory fitted with CCRT700 (ie 1999 CDX/Elites) came with the CCRT version of the 6 disk CDC2.
There is no reason why you can't use the CCRT version of the 4 disk CDC3, as was used in some UK spec Vectra-B
To the OP - assuming this did work once (thus the right CDC3) - are you sure you have the right code, different to the CCRT700 code?
Code input is similar to CDC2, and once you have had a couple of goes, the wait timer starts, initially at 10m from memory, but grows to several hours.  After 10 incorrect attempts, the unit is locked, and needs to be unlocked by a specialist decoding company (not the type selling incorrect codes online).
alexgundes
« Reply #29 on: 04 May 2009, 18:59:15 »
Ok thanks.
is true i try many time the code and now is locked, today i go to office OPEL to resolve the problem. My car is a Vectra B (1999), and the radio must go to portugal to be decoding.
Pages: 1 [2] 3  All   Go Up
