Author Topic: Can a vauxhall CD70 system be fitted in a miggy?  (Read 3783 times)
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« on: 06 May 2009, 12:58:28 »
I just spotted a cd70 navigation system pulled out of a 2006 signum and wondered can this be installed in a miggy? Definitely a tech 2 job .
Can this be done?
« Last Edit: 06 May 2009, 12:59:51 by kumamoto »
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
Re: Can a vauxhall CD70 system be fitted in a miggy?
« Reply #1 on: 06 May 2009, 13:00:32 »
here is the link  http://cgi.ebay.co.uk/Vauxhall-CD70-Navi_W0QQitemZ300312750882QQcmdZViewItemQQptZUK_AudioTVElectronics_GPSSystems_GPSSystems?hash=item300312750882&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A16%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 06 May 2009, 13:10:48 »
i know the Signums display isnt compatible with the Omega's
we have a few Audio Guru's on here one of them will know if the CD70 its self is compatible
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 06 May 2009, 13:15:15 »
No.
The later CD30 / 70 / 90 models used in later Vauxhalls rely heavily on canbus integration with the vehicle, and although the Omega has a "sort" of canbus, its by no means enough to run a later head unit - there just aren`t enough signals to get the thing running.
Radio & Decoding Technician
www.dndservices.co.uk
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #4 on: 06 May 2009, 13:23:12 »
Thanks guys. What a shame!!
After market seems the only option.
« Reply #5 on: 06 May 2009, 13:34:27 »
That CD70 would fit my mum bus though.....
Dave, when you decode these do you provide the code or wipe it?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 06 May 2009, 13:59:07 »
They get reset back to delivery mode so that you can use the Tech2 to program it back in.
If looking at the CD70 / DVD90 make sure you get them in delivery mode if you can, as unlike the CD30, resetting them is a real pain !
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #7 on: 06 May 2009, 14:37:58 »
shame they wont work in an omega even the stering wheel controls are CAN on these!!!
« Reply #8 on: 06 May 2009, 15:15:50 »
Thats a pity as if you supplied the code it could then be used with Tech2 to put that and the screen in delivery mode.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 06 May 2009, 15:52:16 »
No, very different technology - there is no customer entered code whatsoever on these, its purely down to the VIN number stored in several locations on the unit. Twice in the TSOP48, once in the EEprom and a couple of bits of data on the micro. Apart from the micro bits, the VIN number is really easy to spot if you were having a play.
