Author Topic: Radio problem  (Read 4143 times)
big-o-bob
  • Yorkshire
Radio problem
« on: 07 May 2009, 08:35:31 »
Hi
Often, if i have my radio on with the ignition off, and then start the car up, with the radio still on - it loses it's preset channel as though the battery has been disconnected..
Has anyone else had this problem or know what the cause is?.
Thanks
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio problem
« Reply #1 on: 07 May 2009, 09:03:52 »
A model number would help for the radio.
However, common causes for that are
1 - Low Battery power - it may start the car, but if there is not enough to turn the starter and keep everything else live, the radio can lose presets - give the battery a boost and see if problem stops.
2 - Ignition switch fault - a worn switch can momentarily remove the live feed from the radio and other circuits - Only the radio ever shows this fault and again, everything else may appear ok.
3 - Memory eeprom in radio is dying - requires replacement.
Although not an exhaustive list, they are certainly the most common across all vehicles that we see here, and in that order too.
Radio & Decoding Technician
www.dndservices.co.uk
big-o-bob
  • Yorkshire
Re: Radio problem
« Reply #2 on: 07 May 2009, 19:29:41 »
Thanks Dave.
I will find the model number tommorow, as the car is not at my house at the moment.
Very helpful though.
Can the worn ignition switch cause any major issues if it turns out to be this?. :y
damon80
  • Wigan
Re: Radio problem
« Reply #3 on: 07 May 2009, 19:36:32 »
Is your radio the original one, or an aftermarket one?
If it's an aftermarket one, you'll need to join the red and yellow wires together on the iso wiring harness
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio problem
« Reply #4 on: 07 May 2009, 19:52:55 »
NO !!  >:(
Wire it up properly.
Swap the red and yellow over - DO NOT JOIN THEM TOGETHER
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio problem
« Reply #5 on: 07 May 2009, 19:55:08 »
Thanks Dave.
Unsure - when it starts to affect the radio, most people tend to change it at that stage, unsure what long term problems would be - maybe others can advise.
damon80
  • Wigan
Re: Radio problem
« Reply #6 on: 07 May 2009, 19:59:30 »
NO !!  >:(
Whoops - sorry!  :-[
big-o-bob
  • Yorkshire
Re: Radio problem
« Reply #7 on: 08 May 2009, 00:27:23 »
Its the origional stereo.
What are the red and yellow wires for?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio problem
« Reply #8 on: 08 May 2009, 07:58:50 »
That only applies to aftermarket radios - don`t worry about it.
The Ign and permanent feed are swapped over in Vauxhalls from the layout that has come to be accepted as ISO standard. Hence the change if you have an aftermarket stereo.
 8-)
Re: Radio problem
« Reply #9 on: 08 May 2009, 10:30:57 »
What model radio?
ccrt700 with built in phone? They seem fairly prone to that type of fault
big-o-bob
  • Yorkshire
Re: Radio problem
« Reply #10 on: 08 May 2009, 13:34:28 »
[/quote]
 8-)
[/quote]
Right thanks, fully understand now.
big-o-bob
  • Yorkshire
Re: Radio problem
« Reply #11 on: 08 May 2009, 13:37:27 »
What model radio?
I can't check at the moment, the cars layed up at my dads house - i'm changing the oil cooler
The radio has not got a built in phone though.  It has a 4 disc changer.
cheers :y
Welung666
Re: Radio problem
« Reply #12 on: 08 May 2009, 13:47:32 »
What model radio?
cheers :y
It's a facelift tho, so won't have the ccrt700 :-/
big-o-bob
  • Yorkshire
Re: Radio problem
« Reply #13 on: 09 May 2009, 20:16:50 »
What model radio?
CCR2006 :y
