Author Topic: fitting aftermarket speakers  (Read 2644 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
« on: 13 May 2009, 13:36:08 »
once i remove old speakers , front and rear which are both components . will i need any new wiring i.e i have wires going to the tweeters and wires to the main speaker in each door  :o
sam
mathewst
  • Split, Croatia
    • v40
Re: fitting aftermarket speakers
« Reply #1 on: 13 May 2009, 14:54:39 »
Nope, you can use existing wiring but you'll probably need to extend them a little especially if the crossover isn't mounted directly on the tweeter.
Also you'll need to cut the  end of the existing wires because they have plastic endings which fit on opel/vauxhall speakers only
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 13 May 2009, 14:56:17 »
Actually I put new wires from crossover to bass and tweeters.
But I kept the wires going from headunit to crossover
samrey4u
  • norwich
« Reply #3 on: 13 May 2009, 15:11:45 »
thanks guys great help as always  :y :y :y
sam
