Pages: [1] 2 3  All   Go Down
Author Topic: CID - Whats involved?  (Read 9085 times)
miniator
  • Northern Ireland
    • My YouTube Channel
« on: 04 May 2009, 11:33:30 »
i have a NCDC2013 but i would like to upgrade to the CID from the GID....
but whats involved? extra cabling? obviously the CID...ive read about programming and pairing and hte likes but im a little confused. if someone could lay that out nicely for me it would be much appreciated.
and i suppose i should ask....how much are we talking?
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
    • 530D M Sport, 330i Coupe
Re: CID - Whats involved?
« Reply #1 on: 04 May 2009, 11:41:32 »
De-pair GID from 2013
Remove GID from dash
install de-paired CID in dash and locate extra 12pin RGB cable tucked behind dash (hopefully - Elites have it, others probably don't)
Set coding of screen to match wheel size, engine size transmission type etc
pair 2013 to CID
Enjoy
Price varies wildly but expect to pay around £300 - £600 for a good de-paired CID, although there are other options that TheBoy will explain!
« Last Edit: 04 May 2009, 11:42:40 by VXL_V6 »
miniator
  • Northern Ireland
« Reply #2 on: 04 May 2009, 12:00:36 »
£300-£600!!! are ya's wise in the head!!!!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 04 May 2009, 13:31:48 »
they are rare as rocking horse poo!
you will have more sucess finding a depaired one on german ebay www.ebay.de
miniator
  • Northern Ireland
« Reply #4 on: 04 May 2009, 14:53:08 »
if only i spoke german....whats depaired in german anyways lol
can they not be depaired once removed?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 04 May 2009, 14:56:13 »
They certainly can now  :y
Radio & Decoding Technician
www.dndservices.co.uk
miniator
  • Northern Ireland
« Reply #6 on: 04 May 2009, 15:02:33 »
dave to the rescue again!!
got the leads today, cheers man!!
i see a couple on ebay.de but theyre lookin big money for one. if the display its faulty....streaky is the word used....can it be easily fixed?? and will a CID from any car, provided its a NCDC HU, work!?
should also have asked....who makes the screens? Sharp?
« Last Edit: 04 May 2009, 15:07:39 by miniator »
dpanic88
  • West Midlands
« Reply #7 on: 04 May 2009, 18:06:37 »
What's the charge for depairing the CID - have a spare one which is split from its head unit, it works fine no faults just needs depairing ready to use
3.2omegaestate
« Reply #8 on: 04 May 2009, 19:07:49 »
I had a CID that went 'streaky'. The fault was traced to a dry joint on the ribbon cable connector on the screen PCB. This PCB linked the screen to the other 2 PCBs. The joint was approx 0.5mm wide and a good friend of mine managed to re-flow the joint and cure the fault; eventually
The screen is replacable. The original part number is a Sharp LQ5AW126 which I believe has been superceded by a Sharp LQ5AW136 (this needs careful checking though).
As the screen is a distinct separate part within the CID, I believe it (the screen) could be replaced without affected the pairing issue, since the data and pairing code for the CID is held on boards 2 and 3 (taking the screen PCB as board 1) and these are not part of the screen (not CID) assembly.
New Sharp screen is approx £150 - £200
HTH and good luck
miniator
  • Northern Ireland
« Reply #9 on: 04 May 2009, 20:00:21 »
HTH and good luck
those are my kind of prices now...
theres folks on ebay offering to fix CID's so im tempted to get the broken one on ebay.de and send it off on a chance.....
you say they are £150 new....where from tho?
« Reply #10 on: 04 May 2009, 22:11:03 »
Earlier facelifts did not have the rgb cable for CIDs, so may need to do a bit of loom additions
« Reply #11 on: 04 May 2009, 22:13:04 »
hmmm, maybe I should sell some of my headunits and CIDs ::)
« Reply #12 on: 04 May 2009, 22:20:40 »
Let me know if you want to sell the 1100!  :y
« Reply #13 on: 04 May 2009, 23:42:54 »
Its for sale, but reckon I'll get more for it as a 'package' with CID, CDC3 and my conversin loom for prefacelifts...
« Reply #14 on: 04 May 2009, 23:48:07 »
Fair play, i'll keep an eye out for one.  :y
Pages: [1] 2 3  All   Go Up
