Pages: 1 [2] 3  All   Go Down
Author Topic: CID - Whats involved?  (Read 9087 times)
Re: CID - Whats involved?
« Reply #15 on: 05 May 2009, 00:06:36 »
Its for sale, but reckon I'll get more for it as a 'package' with CID, CDC3 and my conversion loom for prefacelifts...
What's the package Jamie? A bit more info please!  ;)
« Last Edit: 05 May 2009, 00:07:00 by Andy_B »
« Reply #16 on: 05 May 2009, 00:18:56 »
The loom bit is simply a modified TM loom, so no mods to the cars loom.
As the CDC is 4 disc, I'd recommend, if you are Bose'd, to move CDC to the bose shelf, which means unclipping the cdc loom back to seat, then swing over to bose shelf.
3.2omegaestate
« Reply #17 on: 05 May 2009, 10:23:54 »
I had a CID that went 'streaky'. The fault was traced to a dry joint on the ribbon cable connector on the screen PCB. This PCB linked the screen to the other 2 PCBs. The joint was approx 0.5mm wide and a good friend of mine managed to re-flow the joint and cure the fault; eventually
The screen is replacable. The original part number is a Sharp LQ5AW126 which I believe has been superceded by a Sharp LQ5AW136 (this needs careful checking though).
As the screen is a distinct separate part within the CID, I believe it (the screen) could be replaced without affected the pairing issue, since the data and pairing code for the CID is held on boards 2 and 3 (taking the screen PCB as board 1) and these are not part of the screen (not CID) assembly.
New Sharp screen is approx £150 - £200
HTH and good luck
those are my kind of prices now...
theres folks on ebay offering to fix CID's so im tempted to get the broken one on ebay.de and send it off on a chance.....
you say they are £150 new....where from tho?
Please remember that it is £150 - 200 for a new Sharp LCD screen, without fitting it into the CID. The CID contains other gubbins and electronics as well, including some circuitry to boost the voltage to 600v IIRC !!!! Be careful if youre poking around inside it.
£150 - £200 is not the price of a new CID; if only and they could be sourced!!!!!!
I am lucky to have two goods friends who are both electrical techies (one works for what was the BBC outside broadcast unit, carrying out electronic equipment repairs) who assisted in the repeated dismantle, repair and reassembly of the unit.
Search the internet for "Sharp +LQ5AW136" copy and paste, the + includes the part number in the search parameter. There are suppliers out there.
HTH
miniator
  • Northern Ireland
    • My YouTube Channel
« Reply #18 on: 05 May 2009, 10:32:15 »
will do thanks.....if i got a streaky screen you think your mate could sort it out for a fee??
theboy....would you happen to have any CID's and a RGB cable spare??
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
3.2omegaestate
« Reply #19 on: 05 May 2009, 11:00:10 »
The friends I mentioned vowed never to take another fault finding mission on , for a CID. If mine went again it would be new LCD time for ease!!!
I have PM'd you. Hope it helps
Ken
« Last Edit: 05 May 2009, 11:03:50 by 3.2omegaestate »
« Reply #20 on: 05 May 2009, 13:14:16 »
The TM loom that was originally fitted to my car was not intended for a CCRT and so did NOT clip onto the back of the radio cage, the plugs are the same electrically but not quite the same physically ie they don't clip on the CCRT cage  ;). The CCRT uses a different TM loom that costs (when I enquired a few years back ) around £160  :o  :o  :o  :o
« Reply #21 on: 05 May 2009, 14:08:38 »
The NCDR1x00 cage isn't a full depth cage, so the missing clips aren't a problem.  The tip is to tape the car loom to tm loom connector under a bar...
miniator
  • Northern Ireland
« Reply #22 on: 05 May 2009, 15:33:14 »
found one on german ebay.....but my german is wild! although the headunit int he signum is the same as mine, will it fit in the dash ok??? and does it work too, the description doesnt make sense when run through a translation site!!
http://cgi.ebay.de/Opel-CID-Vectra-Signum-Navi-NCDC-201X_W0QQitemZ320367294878QQcmdZViewItemQQptZNavigations_Zubeh%C3%B6r?hash=item320367294878&_trksid=p3286.c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
« Reply #23 on: 05 May 2009, 18:19:06 »
Vectra C and Signum displays are not the same as the Omega ones.
The Omega ones were common to the Astra G, Vectra B and Omega
miniator
  • Northern Ireland
« Reply #24 on: 05 May 2009, 19:21:01 »
balls.....thanks mark
« Reply #25 on: 05 May 2009, 20:33:49 »
The Vectra-B/Signum, Astra-H/Zafira-B, Corsa-D ones are very, very different, and will not work in an Omega.
miniator
  • Northern Ireland
« Reply #26 on: 13 May 2009, 11:02:41 »
Can the language be changed from say, German to English on a CID?
    • 530D M Sport, 330i Coupe
« Reply #27 on: 13 May 2009, 12:12:47 »
Yep, with Tech II / Opelscanner
NB. some language functions are set on the Head unit menus.
« Last Edit: 13 May 2009, 12:13:55 by VXL_V6 »
miniator
  • Northern Ireland
« Reply #28 on: 13 May 2009, 13:39:50 »
excellent news, i just need to get someone in NI thats handy with techII then. thanks VXL
« Reply #29 on: 13 May 2009, 19:26:21 »
Yes.
If you're really stuck, I can do via post, but guess the postage may make if prohibitive.
Pages: 1 [2] 3  All   Go Up
