Author Topic: Facelift main beam bulbs  (Read 3023 times)
mathewst
  • Split, Croatia
    • v40
« on: 15 May 2009, 10:05:32 »
Ok the car is facelift 2000, with selfleveling hids, the colour of the main beam is very different (yellow) from the dipped beam(white) so I was thinking of changing the main beam bulbs to get it closer to dipped beam.
Any recomendations anyone? Or even better some links on ebay?
Re: Facelift main beam bulbs
« Reply #1 on: 15 May 2009, 12:06:10 »
To get it to match, you'll need the chavvy xenon bulbs, around 5k in colour.  Most places will sell them.
You may notice a reduction in light output, as those bulb types are compromised for show rather than performance.  Consider doing the fogs as well if you are after the same colour for those as well.
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 15 May 2009, 12:14:05 »
Thanks Boy.
Do you know what is the size of the main beam?
I presume they're H1 but I'm not able to check them now.
Also any experience with osram nightbreakers or some similar bulbs?
« Reply #3 on: 15 May 2009, 12:25:58 »
Thanks Boy.
nightbreakers seem to give better light, but seemingly at the expense of bulb life
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
« Reply #4 on: 19 May 2009, 10:01:23 »
Just put some nightbreakers in mine (min facelift projectors). Tried them last night although not completely dark and they do seem a fair bit better than the normal ones that were in there before.
As for life, the packaging suggests half the life of mormal ones.
Daily drive     - 1997 2.5 CD Auto - 25-35 mpg
Weekend Fun - 2003 RX8 231      - 14-18 mpg
miniator
  • Northern Ireland
    • My YouTube Channel
« Reply #5 on: 19 May 2009, 10:20:57 »
id go for some high wattage normal bulbs as such. Ring do rallysport bulbs and although technically illegal i dont see an issue if your just using them as full beam. H7's come in 130w though on a previous car i used 100/160w H4s....great bulbs!!
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 19 May 2009, 14:06:13 »
if you uprate the bulb wattage uprate the fuses too! otherwise you may experiance some very interesting problems ie the 10a fuse blows and you loose your lights
dont know about the omega but high wattage H7s melt vectra reflectors
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 19 May 2009, 14:51:29 »
I've got no interest in uprating the wattage of the main bulbs, the light is already ok, but want to change the bulbs cause dipped beams are xenon and main beam is regular yellow bulb so it looks a little ridiculous if you ask me.
So plan to match the colours of those two
miniator
  • Northern Ireland
« Reply #8 on: 19 May 2009, 15:29:22 »
ran the H4's for 4 months before selling up, never had a fuse blow!
