Author Topic: puddle lights on bottom of doors  (Read 5355 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
« on: 18 May 2009, 20:01:05 »
all but one of mine work, ive looked at the plug behind door card and changed the bulb to no avail alas  :-/
sam
Re: puddle lights on bottom of doors
« Reply #1 on: 18 May 2009, 20:02:36 »
Door switch? :-/
samrey4u
  • norwich
« Reply #2 on: 18 May 2009, 20:15:24 »
Door switch? :-/
good thinking  :y i will take a look tomorow ty
sam
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 18 May 2009, 21:57:13 »
also check to c if the cabels are getting power / earth, ( multimeter )
He who brakes Looses
To old to die young
samrey4u
  • norwich
« Reply #4 on: 19 May 2009, 05:43:46 »
cheers dave will do  :y
sam
samrey4u
  • norwich
« Reply #5 on: 19 May 2009, 10:47:56 »
definately not door switch as it swithes on interior lights np  :'( help any ideas
sam
« Reply #6 on: 20 May 2009, 14:02:34 »
I have the exact same problem, front passenger side door light doesn't work, all the others do.
wingman
  • Online Online
  • Hastings
    • Grandland GS
« Reply #7 on: 20 May 2009, 14:38:00 »
As LSG1 I have the same problem, except it is drivers side door light that doesn't work, all the others do. Door switch appears OK (interior light works) as does bulb/wiring in puddle light
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 20 May 2009, 16:03:31 »
I got caught out with diagnosing a door switch for a similar problem a few years ago on a Holden. When I pulled the switch out, it had two wires going to the rear of it, and the internals were for two seperate switches but inside one housing -
All I`m suggesting is not to rule out the door switch just because the interior light comes on, pull it out and have a look to see if it has more than one wire going to it, and if it does, then prod around with a meter just to be sure.
Radio & Decoding Technician
www.dndservices.co.uk
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #9 on: 20 May 2009, 16:11:35 »
i had an electrical fire in my V6 Vectra down to the kerb lights
the MV6 doesnt have them i assume there optional extras
just out of interest do the plod omegas have kerb lights as the plod vectras b's do
« Last Edit: 20 May 2009, 16:12:21 by tmx »
« Reply #10 on: 20 May 2009, 16:26:29 »
Mine does thats plod.
unlucky mark mv6
  • tipton,west mids
« Reply #11 on: 20 May 2009, 19:58:02 »
Remove the rubber boot from the door and the a-piller,and check for broken wires.Had an electrical problem with my vec,and turned out to be a broken wire in the boot,obviously the constant opening and closing of the door. :y
samrey4u
  • norwich
« Reply #12 on: 22 May 2009, 21:43:57 »
all sorted now all 4 working it was the door pillar switch  :y :y :y
sam
« Reply #13 on: 22 May 2009, 22:28:52 »
Do I get a prize?  ;)  ;)  ;)  :y
« Reply #14 on: 22 May 2009, 22:36:58 »
I've got an odd puddle light problem, sort this one then Andy !!
Open drivers door : puddle lights on both passenger door and drivers door, and interior light come on
Open Passenger door : puddle light on drivers door and interior light come on ... but NO passenger door light !!
So, bulb works as light comes on with drivers door.
door switch works as interior light and drivers door lights work
So why does the passenger door one only come on with the drivers door ??
If you can sort that there'll be some beer for you at Newent ..  :)
