Author Topic: puddle lights on bottom of doors  (Read 5353 times)
Re: puddle lights on bottom of doors
« Reply #15 on: 23 May 2009, 01:51:09 »
I've got an odd puddle light problem, sort this one then Andy !!
Open drivers door : puddle lights on both passenger door and drivers door, and interior light come on
Open Passenger door : puddle light on drivers door and interior light come on ... but NO passenger door light !!
So, bulb works as light comes on with drivers door.
door switch works as interior light and drivers door lights work
So why does the passenger door one only come on with the drivers door ??
If you can sort that there'll be some beer for you at Newent ..  :)
Errrr? I'll get back to you!  ;D  ;D  ;D  ;D  ;D
gstylebaby
  • stockport
« Reply #16 on: 23 May 2009, 04:07:02 »
A stab in the dark but may be the same thing door switch on the passenger...Stick with me a min i'm thinking that when you open the passenger door that the switch mite cause a sort  :-/ :-/ stopping that light coming on or some thing along them lines. Agian have a check round with a meter and seeing as its only one screw holding it in swap it with the drivers side and see if it works the other way round. ;D ;D
(Bet you all think i'm mad but some times theres methord in madness or just plane stupidity :D :D)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #17 on: 23 May 2009, 08:02:31 »
That sounds like the classic symptoms of the broken cable that mark mv6  was describing earlier.
Radio & Decoding Technician
www.dndservices.co.uk
