Author Topic: siemens ncdc 2013 broken trying to fit alpine head  (Read 8052 times)
ron
  • chelsea sw35bl
« on: 23 May 2009, 17:52:21 »
took car to sextons left it 3-4hrs to try fitting alpine head unit rang me back said the bose amp had power but no sound suggested changing amp said no was working before radio broke said they try again thursday anybody have any idea what could cause no sound to speakers?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: siemens ncdc 2013 broken trying to fit alpine head
« Reply #1 on: 23 May 2009, 17:59:00 »
More info needed, were they trying to make the Alpine HU work with your existing Bose setup? not sure if thats going to work without the correct matching units.
Also what screen do you have of the 2013?
ron
  • chelsea sw35bl
« Reply #2 on: 23 May 2009, 18:03:00 »
colour screen what head unit could i install with bose amp?
zirk
  • Epping Forest
« Reply #3 on: 23 May 2009, 18:09:39 »
Did they de-pair the 2013 with CID (colour screen) before taken out the 2013. What was wrong with the 2013?
« Reply #4 on: 23 May 2009, 18:11:21 »
Right, STOP.
if you are using a colour screen, you have to keep the NCDC201x stereo.
If these idiots are even considering wiring up the Alpine to the Bose unit, immediately demand full refund, and go elsewhere. And audio specialist should know better.
If you want to change to a non NCDC201x radio, you need:
New screen
New wiper stalk
New speakers all round
Remove bose and all the speakers
Remove colour screen
Adapters if you want to use steering wheel controls
Adapters if you want radio info on display
« Reply #5 on: 23 May 2009, 18:12:10 »
tis irrelevent, as colour screen can only be used in conjunction with NCDC201x radio
ron
  • chelsea sw35bl
« Reply #6 on: 23 May 2009, 18:25:26 »
hi the2013 is  not working now shorted has not worked since i need some sound have about £350 to spare what can i do
zirk
  • Epping Forest
« Reply #7 on: 23 May 2009, 18:29:54 »
Agreed, but I was thinking along the lines of if they did Depair at least he could go down the road of sorting a replacement 2013.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 23 May 2009, 18:34:51 »
right from 1st hand experiance i know what happens when you do this having experimented!
if you wire a Non Bose headunit upto a bose amp the headunits amp will burn out within 10 minuites! itll overheat first and then smoke so dont bother trying it!
also it may even damage the bose amp itself
if you have £350 to spend then just get a replacement NCDC! depaired
although DaveDND may be able to make a paired unit depaired again
« Last Edit: 23 May 2009, 18:36:54 by tmx »
ron
  • chelsea sw35bl
« Reply #9 on: 23 May 2009, 18:39:58 »
any ideas anybody give me some music for£350 or fix my 2013 ncdc we tryed german ebay number not working need whole number with direct dialling code thnx
    • 530D M Sport, 330i Coupe
« Reply #10 on: 23 May 2009, 18:43:13 »
If you don't want the 2013 I could use some spares! Is the front Bezel OK? ::)
ron
  • chelsea sw35bl
« Reply #11 on: 23 May 2009, 18:44:58 »
i want to try send it to germany first if it does not cost to much
« Reply #12 on: 23 May 2009, 18:46:53 »
Why to Germany? There are people on here who have a good knowledge of this kit.
TB and I are also stockpiling the NCDx kit  ;D
ron
  • chelsea sw35bl
« Reply #13 on: 23 May 2009, 18:49:13 »
so who wants to fix it
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #14 on: 23 May 2009, 20:33:36 »
pm DaveDND hes our radio fix it man!
