Author Topic: How do I remove an alternator?  (Read 8902 times)
Martin_1962
« on: 01 June 2009, 19:29:33 »
As above - how do I remove it to check it?
Re: How do I remove an alternator?
« Reply #1 on: 01 June 2009, 19:34:48 »
have you measured voltage yet at idle, and 2000rpm?
Martin_1962
« Reply #2 on: 01 June 2009, 20:38:36 »
Nothing coming from it
« Reply #3 on: 01 June 2009, 21:04:08 »
its just bolted on. comes off easy enough, but may need to remove bits to get your fists in there...
Martin_1962
« Reply #4 on: 01 June 2009, 21:54:26 »
Remove from front or from underneath?
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 01 June 2009, 21:55:13 »
from front martin not easy but doable  :y
Martin_1962
« Reply #6 on: 01 June 2009, 22:10:52 »
I haven't removed an alternator for years
Tomorrow I do the first check to see if the cable is definately connected
Then call work
Might say sod it and try a local recon place and see if they do while you wait
« Reply #7 on: 02 June 2009, 09:45:17 »
Easy
Multiram setup out.
Aux belt off.
Disconnect battery
Remove the two securing bolts (one end is torx, the other end hex)
swing the alternator out and disconnect the two rear electrical connections.
Re-fit is the reverse.
Sub 1 hour easy.
Martin_1962
« Reply #8 on: 02 June 2009, 10:13:04 »
Easy
Multiram setup out.
Aux belt off.
Disconnect battery
Sub 1 hour easy.
Due to hand damage (savaged by chipmunks while getting them for sale), time and the fact it is probably repairable it is now at a local auto electrician.
Working from home now as I have no transport.
Martin_1962
« Reply #9 on: 02 June 2009, 16:41:39 »
£163 spent
All the chipmunk money and KF money gone + a lot more
« Reply #10 on: 02 June 2009, 18:31:48 »
£163 spent
That's a lot, especially going off the prices MarkDTM quoted for regulator brushes, and bearings are only cheap (mine come from the stores! ;))
My local autospark seems to charge £25 for everything!  ;D  ;D  ;D
Martin_1962
« Reply #11 on: 02 June 2009, 19:02:35 »
Regulator, cleaned and serviced
I had no other way to get to work and no easy way to ferry bits around
« Reply #12 on: 02 June 2009, 21:42:50 »
What the break is that supposed to do to a solid state device (yours is different to the one in the how to)
That is MUCH to much money!
You could have got a gm one fitted for that money
Martin_1962
« Reply #13 on: 02 June 2009, 21:50:20 »
New regulator fitted
Cleaned
Checked over
110 + vat for a GM exchange.
How was I supposed to get to Reddich running total loss, then back to Inkberrow, then home, then run TL for the next 3 days, could kill the battery.
I didn't want to take any more holiday or lose pay. A days wages dropped is not worth trying to save £40 or £50.
They removed and refitted as well.
Remember - my only car, I have no other way to get to work.
Remember even DIY maintenance sometimes you just have to pay.
