Author Topic: Y26SE Coil pack questions  (Read 2265 times)
Martin_1962
« on: 04 June 2009, 13:02:59 »
1) How to test a coil pack?
2) Can a faulty alternator kill one?
3) Where can I get one from at an affordable price?
Thanks
Martin
    • 530D M Sport, 330i Coupe
Re: Y26SE Coil pack questions
« Reply #1 on: 04 June 2009, 13:19:12 »
Have a 2/4/6 coilpack you can borrow to prove the point if it helps.
Not sure how I would get it to you though? Drop it off at your work fri PM maybe?
Martin_1962
« Reply #2 on: 04 June 2009, 13:27:17 »
That would be brilliant if possible
I'll PM my work address :y
« Reply #3 on: 04 June 2009, 13:38:43 »
I'll bring 1/3/5 as well.
The coils have some rust on them but they do both work.
Martin_1962
« Reply #4 on: 04 June 2009, 14:11:06 »
Thanks :y :y
Martin_1962
« Reply #5 on: 04 June 2009, 19:16:05 »
All is well mechanically
Getting 0300 0302 0304 0306
What wires do I need to check continuity on from coil pack to ECU?
Thanks
« Reply #6 on: 04 June 2009, 19:38:26 »
Pin 1 (Brown) to 0V
Pin 2 (Black/red) to 12V IGN (meter continuity to Pin2 on other coilpack as is common feed and other coilpack is OK).
Pin 3 (Blue/red) to ECU Pin14 (X85)
Pin 4 (Blue/white) to ECU Pin15 (X85)
Pin 5 (Blue/green) to ECU Pin16 (X85)
NB. Don't know if you've seen the M3.1.1 ECU connectors but they are a high density design.
Martin_1962
« Reply #7 on: 04 June 2009, 19:40:26 »
Had a bit of difficulty finding the RPM wire - have been in there before.
Thanks - will check tomorrow, light is just starting to go
Martin_1962
« Reply #8 on: 05 June 2009, 18:45:08 »
No change :'( :'( :'( :'(
Martin_1962
« Reply #9 on: 05 June 2009, 18:46:05 »
And completely out of ideas
